[Mapserver-users] configure options and using --without
Tyler Mitchell
TMitchell at lignum.com
Tue Mar 23 15:22:13 EST 2004
I understand the linking issues but was trying to strip out as much as
possible (purely as an academic exercise) to make sure I really understood
the minimal dependencies.
Thanks for the discussion - it clarified the point for me.
Tyler
mapserver-users-admin at lists.gis.umn.edu wrote on 03/23/2004 11:14:24 AM:
> Tyler Mitchell wrote:
> > I am trying to explicitly disable support for several configure
options
> > and am finding that some appear not to have a "without" option. Is
this
> > normal use of configure options? I see that some options have with
and
> > without in the ./configure --help listing, but assumed that without
should
> > work on any option. What do you think?
> In general, using --without should work even if not explicitly listed in
> the --help.
> > ./configure --without-mpatrol
> > checking whether we should compile in MPATROL support...
> > configure: error: Could not find mpatrol.h or
libmpatrol.a/libmpatrol.so
> > in /
> > data4/src/gis/mapserver-4.0.1/no.
> There was a typo in a variable in the configure.in that caused that. I
> have fixed it in the 4.1 CVS.
> > Here are a few of the other options I found I couldn't explicitly
disable.
> > I assume some of this may be due to requirements of GD and MapServer.
> >>From everything I've read, GD is the only requirement - but of course
> > jpeg, freetype, png (and zlib) could all be used by GD, so I can see
that
> > mapserv won't do a heck of a lot if I disable these, but humour me :)
> > Here's what I found happened when I attempted to disable each of these
> > only PNG appears to not have got added in - any idea why?
> Seems that the configure script isn't bullet-proof and assumes that
> nobody will try to disable an option that's already built into their
> system. i.e. if your GD was built with jpeg, zlib, png and/or freetype,
> then having the ability to disable some or all of them in MapServer's
> Makefile would only result in linking problems. Since that doesn't
> impact usage in normal conditions I didn't really investigate any
> further, but you could always file this as a bug.
> Daniel
> Daniel Morissette dmorissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
