[Mapserver-users] Problem with background color ://: Symbology
Stéphane RIFF
stephane.riff at cerene.fr
Wed Mar 24 03:49:07 EST 2004
First i have a problem with background color of map....
the problem is when i turn off a specific layer (here :
'Numero_Departements', see .map file below), background color of map is
changed and it restore the good color when i turn back on this layer
Does anybody already saw this ???
The second question is about symbology...
I want to set a symbology on a layer but i can't figure how to do it :
One layer with 3 classes based on one field
'product' which can be 'GPS', 'MEASURE','FIXED'. This select the symbol
for each class .... here
no problems
Now i want to set the color of symbols based
on another field 'state' which can be 'DONE','CLOSED','TOBEDONE'. This
can be done by a layer with 3*3 class with each
class with an expression like : [product] = 'GPS' AND [state] = 'DONE' .
But i would keep my layer with only 3 class is it
possible ???
Here is my .map file for the first problem :
# Start of map file
NAME CRN
STATUS ON
SIZE 600 600
EXTENT 47673.624 1616618.5 1197873.624 2677218.5
UNITS METERS
SHAPEPATH "../data"
IMAGECOLOR 80 80 80
TRANSPARENT OFF
SYMBOLSET "../symbols/symbols.sym"
FONTSET "../fonts/font.list"
IMAGETYPE PNG
# Start of web interface definition
WEB
MINSCALE 5000
MAXSCALE 100000000
IMAGEPATH "/var/mapserver/www/tmp/"
IMAGEURL "/tmp/"
#ERROR "/mapServ/error.html"
METADATA
WMS_SRS "EPSG:27582"
END
END
QUERYMAP
SIZE -1 -1
STATUS ON
STYLE HILITE
COLOR 255 255 0
END
# Start of reference map
REFERENCE
STATUS ON
EXTENT -2646.55843466 1564942.61318 1257407.47103 2722306.80918
IMAGE ../img/nrefmap.png
SIZE 115 106
OUTLINECOLOR 0 0 255
COLOR -1 -1 -1
END
# Start of legend
LEGEND
STATUS ON
KEYSIZE 18 12
END
# Start of scalebar
SCALEBAR
IMAGECOLOR 80 80 80
LABEL
COLOR 255 255 255
SIZE tiny
END
STYLE 1
SIZE 600 2
COLOR 255 255 255
UNITS KILOMETERS
INTERVALS 6
TRANSPARENT FALSE
STATUS ON
END
# Start of layer definitions
LAYER
NAME "250000"
TILEINDEX "250000"
TILEITEM "LOCATION"
TYPE RASTER
STATUS OFF
OFFSITE 0
MAXSCALE 500000
GROUP "Images"
CLASS
NAME "Fond Raster 250000"
END
METADATA
LYRNAME "250000"
QUERYING_FILEDS ""
WMS_ORDER "0"
END
END
LAYER
CONNECTIONTYPE postgis
NAME "Contour_France"
CONNECTION "host=localhost dbname=mapserver port=5432 user=nobody"
DATA "the_geom from giscontourfrance"
TYPE LINE
STATUS ON
GROUP "Contour"
HEADER blank.html
FOOTER blank.html
CLASS
SYMBOL "dashline"
COLOR 0 153 255
SIZE 3
END
METADATA
LYRNAME "France"
TABLE_NAME "giscontourfrance"
RESULT_FIELDS ""
QUERYABLE_FIELDS ""
WMS_ORDER "1"
END
END
LAYER
NAME "Contour_Departements"
DATA "the_geom from giscontourdepartement"
TYPE LINE
STATUS ON
MAXSCALE 100000000
MINSCALE 450000
GROUP "Contour"
HEADER blank.html
FOOTER blank.html
CLASS
COLOR 255 128 64
END
METADATA
LYRNAME "Départements"
TABLE_NAME "giscontourdepartement"
RESULT_FIELDS ""
QUERYABLE_FIELDS ""
WMS_ORDER "2"
END
END
LAYER
DATA "the_geom from giscontourcommune"
NAME "Contour_Communes"
TYPE POLYGON
STATUS ON
MINSCALE 5000
MAXSCALE 450000
GROUP "Contour"
HEADER "blank.html"
FOOTER "blank.html"
LABELITEM "nom_comm"
CLASS
OUTLINECOLOR 250 194 5
SIZE 4
SYMBOL "dashline"
LABEL
TYPE TRUETYPE
FONT "Arialbd"
buffer 1
outlinecolor 255 255 255
COLOR 0 0 255
POSITION CC
SIZE 10
END
END
METADATA
LYRNAME "Communes"
TABLE_NAME "giscontourcommune"
RESULT_FIELDS ""
QUERYABLE_FIELDS ""
WMS_ORDER "3"
END
END
LAYER
DATA "the_geom from gistxtdepartement"
NAME "Numero_Departements"
TYPE POINT
STATUS ON
MAXSCALE 100000000
MINSCALE 450000
GROUP "Texte"
LABELITEM "textstring"
HEADER blank.html
FOOTER blank.html
CLASS
COLOR 244 190 80
SIZE 8
SYMBOL "point1"
LABEL
TYPE TRUETYPE
FONT "Arialbd"
BUFFER 1
outlinecolor 255 255 0
COLOR 255 0 0
POSITION CC
SIZE 8
PARTIALS TRUE
FORCE TRUE
END
END
METADATA
LYRNAME "N° de Départements"
TABLE_NAME "gistxtdepartement"
RESULT_FIELDS ""
QUERYABLE_FIELDS ""
WMS_ORDER "5"
END
END
END # Map File
