[Mapserver-users] projection - UTM and geographic
Frank Warmerdam
warmerdam at pobox.com
Wed Mar 24 08:48:23 EST 2004
Steve McCrone wrote:
> I know this question hs been asked many times, but I can't seeme to find the
> solution.
> I ahve a shape file that is in geographics (i.e. WGS84 lat/lon). I wish to
> display the shape file in UTM m. I tried putting the projection definition
> but the map does not show. My mouse coordinates (within jBox) are expressed
> in UTM m, but map is not dispalyed.
> PROJECTION
> "proj=utm"
> "datum=WGS84"
> END
> I also have -
> EXTENT 111000 592500 279600 711000
> UNITS METERS
Steve,
You need the UTM zone you are working in as well.
eg.
PROJECTION
"proj=utm"
"zone=11"
"datum=WGS84"
END
Also, I assume you have a projection block on the layer describing it
as geographic, right? Something like:
PROJECTION
"proj=latlong"
"datum=WGS84"
END
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
