R: [Mapserver-users] projection - UTM and geographic
Ballini Yvain
Ballini.Yvain at seat.it
Wed Mar 24 08:51:10 EST 2004
You have to give a precision about your zone, for example zone = 32, for the longitudes between + 6° and +12°, zone = 33 for the longitudes between +12° and +18°...like this:
PROJECTION
"proj=utm"
"ellps=WGS84"
"datum=WGS84"
"zone=32"
"north"
END
Then the EXTENT gives you the coordinates Xmin Ymin Xmax Ymax with this rule:
Y = 0 at the equator line
X = 500000 (meters) at the longitude +9° for the zone UTM 32, or at the longitude +15° for the zone UTM 33...
You should control that the features you want to see are in this range of coordinates.
Regards,
Yvain.
-----Messaggio originale-----
Da: mapserver-users-admin at lists.gis.umn.edu [mailto:mapserver-users-admin at lists.gis.umn.edu] Per conto di Steve McCrone
Inviato: mercoledì 24 marzo 2004 13.28
A: mapserver-users at lists.gis.umn.edu
Oggetto: [Mapserver-users] projection - UTM and geographic
I know this question hs been asked many times, but I can't seeme to find the solution.
I ahve a shape file that is in geographics (i.e. WGS84 lat/lon). I wish to display the shape file in UTM m. I tried putting the projection definition but the map does not show. My mouse coordinates (within jBox) are expressed in UTM m, but map is not dispalyed.
PROJECTION
"proj=utm"
"datum=WGS84"
END
I also have -
EXTENT 111000 592500 279600 711000
UNITS METERS
Any ideas?
Thanks
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
