[Mapserver-users] postgis data statement
Pericles Nacionales
nacional at cbs.umn.edu
Thu Mar 25 10:51:48 EST 2004
Gernot,
Zamil is correct. If the SQL statement worked in psql (or some other
frontend), it should work in MapServer. If not, the first place to check
would be your PostgreSQL configuration and permissions. If your database
is running remotely you might want to check that you have configured
postgres to accept remote connections. If that is the case, try
connecting as postgres (or whatever pg admin account you created). If it
works, read the PostgreSQL docs for adding users. Sometimes it's just a
matter of giving an existing database user select privileges on your
postgis tables. I've posted other messages to related questions in the
past. Have a look at the MapServer-users archive as I don't have a
browser open.
Cheers!
Pericles S. Nacionales
nacional at biosci.umn.edu
On Thu, 25 Mar 2004, Zamil Murji wrote:
> hi,
> Maybe it isn't the data statement that is hooped. Maybe you don't have the proper permissions set for the database. Does the user/password that you supply to your connection string work? Is it a TRUSTed user? Maybe you need to give the box that mapserver is installed on TRUSTed access to that postgres db. Take a look at your pg_conf.hba file (i think that is what it is called).
> Hope this helps.
> Zamil
> -----Original Message-----
> From: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of knozi
> Sent: Thursday, March 25, 2004 4:34 AM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] postgis data statement
> hi list,
> i've some problems with a postgis data statement.
> DATA "the_geom from
> (select gd_world_samplesite.the_geom,td_samplesite.maxdepth,case
> when td_samplesite.maxdepth > 1000 then 1
> when td_samplesite.maxdepth > 500 then 2
> else 3
> end as myclass
> from gd_world_samplesite,td_samplesite where
> gd_world_samplesite.ssid = td_samplesite.samplesiteid)
> as foo using unique gd_world_samplesite.oid using SRID=4326"
> when I execute the statement in postgres it works fine, but mapserver cannot
> handle it.
> The funny thing is that a similar statement on the same server, but
> accessing another database, works.
> I'm using linux, postgresql 7.3.4, postgis 8.1 and Mapserver 4.1.
> any hints?
> thanks,
> gernot
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
