[Mapserver-users] postgis data statement
Gernot Katzlberger
knozi at gmx.at
Fri Mar 26 08:14:31 EST 2004
hi pericles, zamil & list,
my postgis data statement works now in Mapserver, but it needs ~5 min to
render it. when I start it, 99% of my system cpu usage is occupied by one
process:
postgres: {user} {database} 127.0.0.1 FETCH
when I execute it in psql it works in milliseconds.
mapserver and postgresql/postgis are on the same server. I also checked the
user privileges.
many thanks for your help,
gernot
-----Ursprüngliche Nachricht-----
Von: mapserver-users-admin at lists.gis.umn.edu
[mailto:mapserver-users-admin at lists.gis.umn.edu] Im Auftrag von Pericles
Nacionales
Gesendet: Donnerstag, 25. März 2004 16:52
An: Zamil Murji
Cc: knozi; mapserver-users at lists.gis.umn.edu
Betreff: RE: [Mapserver-users] postgis data statement
Gernot,
Zamil is correct. If the SQL statement worked in psql (or some other
frontend), it should work in MapServer. If not, the first place to check
would be your PostgreSQL configuration and permissions. If your database
is running remotely you might want to check that you have configured
postgres to accept remote connections. If that is the case, try
connecting as postgres (or whatever pg admin account you created). If it
works, read the PostgreSQL docs for adding users. Sometimes it's just a
matter of giving an existing database user select privileges on your
postgis tables. I've posted other messages to related questions in the
past. Have a look at the MapServer-users archive as I don't have a
browser open.
Cheers!
Pericles S. Nacionales
nacional at biosci.umn.edu
On Thu, 25 Mar 2004, Zamil Murji wrote:
> hi,
> Maybe it isn't the data statement that is hooped. Maybe you don't have the
proper permissions set for the database. Does the user/password that you
supply to your connection string work? Is it a TRUSTed user? Maybe you need
to give the box that mapserver is installed on TRUSTed access to that
postgres db. Take a look at your pg_conf.hba file (i think that is what it
is called).
> Hope this helps.
> Zamil
> -----Original Message-----
> From: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of knozi
> Sent: Thursday, March 25, 2004 4:34 AM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] postgis data statement
> hi list,
> i've some problems with a postgis data statement.
> DATA "the_geom from
> (select gd_world_samplesite.the_geom,td_samplesite.maxdepth,case
> when td_samplesite.maxdepth > 1000 then 1
> when td_samplesite.maxdepth > 500 then 2
> else 3
> end as myclass
> from gd_world_samplesite,td_samplesite where
> gd_world_samplesite.ssid = td_samplesite.samplesiteid)
> as foo using unique gd_world_samplesite.oid using SRID=4326"
> when I execute the statement in postgres it works fine, but mapserver
cannot
> handle it.
> The funny thing is that a similar statement on the same server, but
> accessing another database, works.
> I'm using linux, postgresql 7.3.4, postgis 8.1 and Mapserver 4.1.
> any hints?
> thanks,
> gernot
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
