[Mapserver-users] TRANSPARENCY + text embedded layer
Jason M. Nielsen
jnielsen at aero-graphics.com
Fri Mar 26 12:02:49 EST 2004
Quoting Eric Bridger <eric at gomoos.org>:
> On Fri, 2004-03-26 at 10:46, Frank Warmerdam wrote:
> > Jason M. Nielsen wrote:
> > > Does the TRANSPARENCY tag work with embedding text as part of the image
> as
> > > listed below or am I simply doing something wrong?
> > I don't know if there is a way to force text to render immediately rather
> > than saving it up, but if there is that is what you will need.
> You can use: LABELCACHE OFF in your LAYER definition. Default is ON.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Thanks for help everyone.
Looks like POSTLABELCACHE set to true is what I am after. It allows the
transparency to be applied and makes the text appear over the other elements.
