[Mapserver-users] TRANSPARENCY + text embedded layer
Eric Bridger
eric at gomoos.org
Fri Mar 26 11:24:12 EST 2004
On Fri, 2004-03-26 at 10:46, Frank Warmerdam wrote:
> Jason M. Nielsen wrote:
> > Does the TRANSPARENCY tag work with embedding text as part of the image as
> > listed below or am I simply doing something wrong?
> I don't know if there is a way to force text to render immediately rather
> than saving it up, but if there is that is what you will need.
You can use: LABELCACHE OFF in your LAYER definition. Default is ON.
