[Mapserver-users] tile indexing problem
Howard Mark
MHoward at spaceimaging.com
Fri Mar 26 13:30:30 EST 2004
Toni,
In your example, "ratser.shp" is the index (shape) file. Is the spelling right?
The "Nome" attribute should contain the complete path to the raster file that the corresponding shape represents.
Field1 Nome
Shape1 /var/www/data/raster/F4-N2.jpg
Shape2 /var/www/data/raster/F4-N3.jpg
Shape3 /var/www/data/raster/F4-N4.jpg
Mark
-----Original Message-----
From: Antonio Cosenza [mailto:antonio.cosenza at polito.it]
Sent: Friday, March 26, 2004 11:21 AM
To: Howard Mark; mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] tile indexing problem
mark,
what do you mean for index file? shapefile? no, there is a fiield
("nome") with only the file names, without the full path...
I'm runnign the system on Linux, so I have to include /var/www/... in
the index file?
thanks
>Toni,
>Are you including the complete path to the raster file in the index file? E.g.
>Mark
>From: mapserver-users-admin at lists.gis.umn.edu [mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of Antonio Cosenza
>Sent: Friday, March 26, 2004 5:14 AM
>To: mapserver-users at lists.gis.umn.edu
>Subject: [Mapserver-users] tile indexing problem
>hi guys,
>i got a little problem with mapserver tile indexing.
>This is my situation:
>- i got a polygon shape file (raster.shp) of rectangular polygons with 9
>attributes in the dbf file (raster.dbf).
>- one of the the attribute's names is 'Nome', which contains the raster
>file name, like F4-N2.jpg.
>can i use this layer to see my jpeg raster files draw up ?
>LAYER
> NAME "raster"
> STATUS ON
> TILEINDEX "ratser.shp"
> TILEITEM "Nome"
> TYPE RASTER
> END
>thanksss
>toni
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
>This message is intended only for the use of the Addressee and may
>contain information that is PRIVILEGED and CONFIDENTIAL.
>If you are not the intended recipient, you are hereby notified that any
>dissemination of this communication is strictly prohibited. If you have
>received this communication in error, please erase all copies of the
>message and its attachments and notify Space Imaging immediately.
