[Mapserver-users] tile indexing problem
Antonio Cosenza
antonio.cosenza at polito.it
Fri Mar 26 13:38:45 EST 2004
thanks for your suggestions!!!
now i will try with this help!
thank you very much mark.
toni
>Toni,
>In your example, "ratser.shp" is the index (shape) file. Is the spelling right?
>The "Nome" attribute should contain the complete path to the raster file that the corresponding shape represents.
>Field1 Nome
>Shape1 /var/www/data/raster/F4-N2.jpg
>Shape2 /var/www/data/raster/F4-N3.jpg
>Shape3 /var/www/data/raster/F4-N4.jpg
>Mark
>-----Original Message-----
>From: Antonio Cosenza [mailto:antonio.cosenza at polito.it]
>Sent: Friday, March 26, 2004 11:21 AM
>To: Howard Mark; mapserver-users at lists.gis.umn.edu
>Subject: Re: [Mapserver-users] tile indexing problem
>mark,
>what do you mean for index file? shapefile? no, there is a fiield
>("nome") with only the file names, without the full path...
>I'm runnign the system on Linux, so I have to include /var/www/... in
>the index file?
>thanks
>>Toni,
>>Are you including the complete path to the raster file in the index file? E.g.
>>Mark
>>From: mapserver-users-admin at lists.gis.umn.edu [mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of Antonio Cosenza
>>Sent: Friday, March 26, 2004 5:14 AM
>>To: mapserver-users at lists.gis.umn.edu
>>Subject: [Mapserver-users] tile indexing problem
>>hi guys,
>>i got a little problem with mapserver tile indexing.
>>This is my situation:
>>- i got a polygon shape file (raster.shp) of rectangular polygons with 9
>>attributes in the dbf file (raster.dbf).
>>- one of the the attribute's names is 'Nome', which contains the raster
>>file name, like F4-N2.jpg.
>>can i use this layer to see my jpeg raster files draw up ?
>>LAYER
>> NAME "raster"
>> STATUS ON
>> TILEINDEX "ratser.shp"
>> TILEITEM "Nome"
>> TYPE RASTER
>>END
>>thanksss
>>toni
>>_______________________________________________
>>Mapserver-users mailing list
>>Mapserver-users at lists.gis.umn.edu
>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
>>This message is intended only for the use of the Addressee and may
>>contain information that is PRIVILEGED and CONFIDENTIAL.
>>If you are not the intended recipient, you are hereby notified that any
>>dissemination of this communication is strictly prohibited. If you have
>>received this communication in error, please erase all copies of the
>>message and its attachments and notify Space Imaging immediately.
