[Mapserver-users] Newbie Question about rasters
Ed McNierney
ed at topozone.com
Fri Mar 26 18:28:33 EST 2004
Paul -
JPEG is a very poor format type to use for geospatial data, mainly due
to performance issues (you need to read and decode the entire image just
to get the value of one pixel). It seems likely that MapServer is not
reading georeference information for your JPEG, while ArcGIS is.
What do you get when you run "mapserv -v" from the command line?
What is the filename of the georeference "world" file? It will be
raster/ak.something
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com
-----Original Message-----
From: Paul VanDyke [mailto:pvandyke at kib.co.kodiak.ak.us]
Sent: Friday, March 26, 2004 5:50 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] Newbie Question about rasters
I've got a working installation of Mapserver w/ some test maps @
209.165.152.94. Please feel free to drop by and check them out. I'd
like to add a raster image layer to my maps. I can't seem to get the
raster working w/ Mapserver. I am using the same raster image in ArcGIS
and it works fine.
I've tried several different things to try and make it work. Please
give me any hints, clues or advice that you think is relative. No help
will be turned away. :-)
Here is my map file:
MAP
NAME map6
IMAGETYPE PNG24
EXTENT -903026 648632 1888140 1849511
SIZE 800 400
SHAPEPATH "data"
IMAGECOLOR 255 255 255
# DEBUG ON
WEB
TEMPLATE 'map6.html'
IMAGEPATH 'c:/program files/apache group/apache2/htdocs/tmp/'
IMAGEURL '/tmp/'
# LOG 'c:\mapserver.log'
END
# Start of LAYER DEFINITIONS -----------------------------
LAYER # water
NAME water
DATA kib_boundary
STATUS DEFAULT
TYPE POLYGON
CLASS
STYLE
COLOR 115 207 255
OUTLINECOLOR 32 32 32
END
END
END
LAYER # coast
NAME coast
DATA kib_coast
STATUS DEFAULT
TYPE POLYGON
CLASS
STYLE
COLOR 0 216 56
END
END
END
LAYER # MODIS raster layer begins here
NAME modis
DATA "raster/ak.jpg"
STATUS DEFAULT
TYPE RASTER
# PROCESSING "BANDS=1"
# OFFSITE 71 74 65
END # MODIS raster layer ends here
LAYER # parcels polygon layer begins here
NAME parcels
DATA parcels2
STATUS ON
TYPE POLYGON
CLASS
STYLE
COLOR 241 238 163
END
END
END # States polygon layer ends here
LAYER # lakes
NAME lakes
DATA lake
STATUS OFF
TYPE POLYGON
CLASS
STYLE
COLOR 39 70 255
END
END
END
LAYER # rivers
NAME rivers
DATA river
STATUS OFF
TYPE POLYGON
CLASS
STYLE
COLOR 39 70 255
END
END
END
LAYER # roads
NAME roads
DATA roads
STATUS OFF
TYPE LINE
CLASS
STYLE
COLOR 0 0 0
END
END
END
SCALEBAR
LABEL
COLOR 0 0 0
SIZE TINY
END
STYLE 1
SIZE 100 2
COLOR 0 0 0
UNITS MILES
INTERVALS 2
TRANSPARENT FALSE
STATUS ON
END
# End of LAYER DEFINITIONS -------------------------------
END # end of map file/object
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
