[Mapserver-users] Itasca demo problems
Mike Reilly
mikereilly_7 at hotmail.com
Sun Mar 28 16:51:30 EST 2004
>From: "Spyros Michas" <smichas at hydroex.gr>
>To: <mapserver-users at lists.gis.umn.edu>
>CC: <smichas at hydroex.gr>
>Subject: [Mapserver-users] Itasca demo problems
>Date: Sun, 28 Mar 2004 23:34:35 +0300
>Hi,
>I've setup mapserver 4.0 on my Windows XPpro/Apache 2.0.48 machine at home.
>Then I installed the workshop Itasca demo.
>I adjust index.html and itasca.map files and then I run index.html. The
>first three basic options simply do not respond at all.
>The last two options (the frame options) however, work! The top frame show
>the map (which means that mapserver is working), but the lower frame
>produces a standard webserver "Not found" error, where it is stated that it
>could not find a blank.html file in cgi-bin/workshop. Now "workshop" is my
>working folder on the web root, so I assume I have made a path error
>somewhere. I carefully check the index.html and itasca.map path entries it
>the relative lines and it looks ok.
>Anyway, after I make query requests, the lower frame responds ok, producing
>either tables or "empty query response" errors. When I switch back to
>"browse" modes, I get the same "Not found" error. Could this be a bug in
>the demo files?
>Does anyone see any possible errors in the above procedures?
>Thank you.
>Spyros Michas
_________________________________________________________________
STOP MORE SPAM with the MSN Premium and get 2 months FREE*
http://join.msn.com/?pgmarket=en-ca&page=byoa/prem&xAPID=1994&DI=1034&SU=http://hotmail.com/enca&HL=Market_MSNIS_Taglines
