[Mapserver-users] Itasca demo problems
Spyros Michas
smichas at hydroex.gr
Sun Mar 28 15:34:35 EST 2004
This is a multi-part message in MIME format.
------=_NextPart_000_0005_01C4151D.3A7B98F0
Content-Type: text/plain;
charset="iso-8859-7"
Content-Transfer-Encoding: quoted-printable
I've setup mapserver 4.0 on my Windows XPpro/Apache 2.0.48 machine at =
home. Then I installed the workshop Itasca demo.
I adjust index.html and itasca.map files and then I run index.html. The =
first three basic options simply do not respond at all.
The last two options (the frame options) however, work! The top frame =
show the map (which means that mapserver is working), but the lower =
frame produces a standard webserver "Not found" error, where it is =
stated that it could not find a blank.html file in cgi-bin/workshop. Now =
"workshop" is my working folder on the web root, so I assume I have made =
a path error somewhere. I carefully check the index.html and itasca.map =
path entries it the relative lines and it looks ok.
Anyway, after I make query requests, the lower frame responds ok, =
producing either tables or "empty query response" errors. When I switch =
back to "browse" modes, I get the same "Not found" error. Could this be =
a bug in the demo files?
Does anyone see any possible errors in the above procedures?
Thank you.
Spyros Michas
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-7">
<META content=3D"MSHTML 6.00.2800.1170" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Hi,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>I've setup mapserver 4.0 on my =
Windows=20
XPpro/Apache 2.0.48 machine at home. Then I installed the workshop =
Itasca=20
demo.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I adjust index.html and itasca.map =
files and then I=20
run index.html. The first three basic options simply do not respond at=20
all.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>The last two options (the frame =
options) however,=20
work! The top frame show the map (which means that mapserver is =
working), but=20
the lower frame produces a standard webserver "Not found" error, where =
it is=20
a path=20
error somewhere. I carefully check the index.html and itasca.map path =
entries it=20
the relative lines and it looks ok.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Anyway, after I make query requests, =
the lower=20
frame responds ok, producing either tables or "empty query response" =
errors.=20
When I switch back to "browse" modes, I get the same "Not found" error. =
Could=20
this be a bug in the demo files?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Does anyone see any possible errors in =
the above=20
procedures?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thank you.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Spyros =
Michas</FONT></DIV></BODY></HTML>
------=_NextPart_000_0005_01C4151D.3A7B98F0--
