[Mapserver-users] drawing lines with mapscript
Jeff Hoffmann
jeff at propertykey.com
Mon Mar 29 16:24:33 EST 2004
I'm trying to create lines programmatically & draw them using mapscript,
but I just can't seem to get any output. It doesn't throw any errors,
but I don't see any output, either. I've done it before with points &
rectangles, but it looks like lines don't have a draw function defined
for them the way points & rectangles do so I'm trying to turn the
lineObj into a shapeObj and draw that. The line that I'm adding to the
shape has points with reasonable coordinates so I'm assuming that's not
the problem. I don't know if I'm doing the class stuff right, though,
but I can't find much documentation on how that works when drawing a
shape. Can someone give me an example of how to do this? Here's
basically what I've been trying to do:
$layer = $map->getLayerByName('line_layer');
$layer->{status} = 1;
$class = $layer->getClass(0);
$class->setText($layer,"LINE");
my $shape = new mapscript::shapeObj($mapscript::MS_SHAPE_LINE);
$shape->add($line);
$shape->draw($map, $layer, $img);
Here's the layer definition:
LAYER
NAME line_layer
STATUS OFF
PROJECTION
"init=epsg:26958"
END
TYPE LINE
CLASS
LABEL
ANGLE AUTO
FONT arial
TYPE TRUETYPE
POSITION UC
SIZE 7
COLOR 0 0 0
END
COLOR 0 0 0
END
END
Jeff Hoffmann
PropertyKey.com
