[Mapserver-users] polygon label placement
    Tyler Mitchell
    TMitchell at lignum.com
    Tue Mar 30 08:26:03 PST 2004
I thought POSITION AUTO helped with this?  But maybe I'm dreaming..
> On Mon, 2004-03-29 at 14:54, Dean Gadoury wrote:
> > Hi,
> > Every now and then I need to label polygons in MapServer and I'm often
> > unsatisfied with the resulting placement. Labeling is fine for points
> > and lines, but when it comes to polygons it can be unpredictable. I've
> > attached an image produced by MapServer in which the label for Florida
> > is in an odd location. Does anyone have any insight into how MapServer
> > decides where to place labels in polygons?
> > If I'm not mistaken the POSITION parameter will only place the label
> > relative to the point at which MapServer decides the label will go.
> > Depending on the label's POSITION its quite possible to have labels
that
> > fall completely outside a polygon. Is there a way to force labels to
be
> > within a polygon? Is there anything else I'm missing?
> > In the attached image the label position is CC and the label is way up
> > on the FL/AL border.
> > Dean
> "He's no geek.His tan's too good." -Benjamin Choate
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
More information about the MapServer-users
