[Mapserver-users] polygon label placement
Pericles S. Nacionales
nacional at cbs.umn.edu
Mon Mar 29 23:17:57 EST 2004
Dean,
Just a guess but is it possible that you have a sliver polygon and that
polygon's the one getting labeled?
-Perry
On Mon, 2004-03-29 at 14:54, Dean Gadoury wrote:
> Hi,
> Every now and then I need to label polygons in MapServer and I'm often
> unsatisfied with the resulting placement. Labeling is fine for points
> and lines, but when it comes to polygons it can be unpredictable. I've
> attached an image produced by MapServer in which the label for Florida
> is in an odd location. Does anyone have any insight into how MapServer
> decides where to place labels in polygons?
> If I'm not mistaken the POSITION parameter will only place the label
> relative to the point at which MapServer decides the label will go.
> Depending on the label's POSITION its quite possible to have labels that
> fall completely outside a polygon. Is there a way to force labels to be
> within a polygon? Is there anything else I'm missing?
> In the attached image the label position is CC and the label is way up
> on the FL/AL border.
> Dean
"He's no geek.His tan's too good." -Benjamin Choate
