Hi there, I'm playing around with the flash output which works fine. But when I use drawLegend or DrawScalebar a 0 kO swf file is generated and the script never stops. Using the same mapfile with JPEG or PNG output works fine. Any idea ? Thanks Guillaume SUEUR --
