[Mapserver-users] reducing RGB maps to 8bit
Ken Boss
Ken.Boss at dnr.state.mn.us
Tue Mar 30 15:28:36 EST 2004
Jan--
Hope I'm not catching you after a full week's worth of coding on this;
didn't see your message until a couple days ago, and then I needed to
confirm with the software vendor that this was in fact possible.
Anyway, Image Alchemy from Handmade Software, Inc., has this
functionality built in (-L option on the command line). You run the
software once with your list of images as input, and it generates a file
containing the optimized palette for those images. Then you batch up a
process to transform them all to 8bit, using the palette you generated
in the first step.
Image Alchemy is a relatively inexpensive commercial software product
that runs on any OS you're likely to be using; I've been using it for
years on both Solaris and Windows and have been very happy with it. You
can learn more at www.handmadesw.com.
Note that I am not affiliated with Handmade Software in any way, other
than being a satisfied customer.
--Ken
>>> Jan Hartmann <jhart at frw.uva.nl> 3/23/2004 3:53:30 AM >>>
Not a specific MapServer question, but I guess there are people on this
list who know something about this. I have about 600 historical
cadastral maps dating from about 1830. They have been scanned as 24bits
jpg files, and each map is about 4000*4000 pixels. To display them
efficiently with MapServer I need to transform them to 8bit, all in the
same palette. Colors on the different maps don't match exactly, due to
two centuries of wear and tear The question is: does anyone know a way
to compute some sort of optimal colormap for this amount of data,
something like "imagemagick -display" or the gdal-utility "rgb2pct.py",
not for a single file, but for a large set of images. There is some
literature about it, e.g. "comp.graphics.algorithms 3.02" and
"graphics
gems", but before I start programming myself, perhaps someone knows an
easier way.
Thanks,
Jan
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
