[Mapserver-users] epsg error ! help me !
Dharani Babu
dharanibabus at hotmail.com
Wed Mar 31 02:20:09 EST 2004
Hi all
I am using both ms4w package and also IIS version of the map server . I
found a rather strange problem . I am working with examples on the map
server tutorial to know deep about the way CGI variables work ...
I am trying to render a simple shape file layer by passing the CGI variable
from url without template html
http://localhost/cgi-bin/mapserv_40.exe?map=C:/ms4w/Apache/htdocs/demof/example1-1.map&mode=map
in the ms4w apache package and also in IIS based package like this
http://localhost/cgi-bin/mapserv_40.exe?map=C:/Inetpub/wwwroot/iisdemo/example1-1.map&mode=map
But I got the following errors in ms4w package trials ...
msProcessProjection(): Projection library error. no options found in 'init'
file
and the following in IIS based trails
msProcessProjection(): init:epsg:4376 error ..
why so ? I checked the C:/ms4w/proj/epsg and found the line 4376 ...the same
I found at
C:/proj for IIS...but both the file sizes differ ( ms4w epsg file size is
around 190 kb whereas file size of C:/Proj of IIS version is 300kb ) and but
still I dont know why I have this error ...
This is the map file used in example 1 ...
MAP
IMAGETYPE PNG
EXTENT 201621.496941 -294488.285333 1425518.020722 498254.511514
SIZE 400 300
SHAPEPATH "data1/data"
IMAGECOLOR 255 255 255
PROJECTION
#"proj=laea"
# "ellps=clrk66"
# "lat_0=45"
# "lon_0=-100"
# Alternatively, you can specify an EPSG code.
# "init=epsg:2163"
END
# Start of LAYER DEFINITIONS ---------------------------------------------
LAYER # States polygon layer begins here
NAME states
DATA states_ugl
STATUS DEFAULT
TYPE POLYGON
PROJECTION
"init=epsg:4376"
END
CLASS
COLOR 232 232 232
OUTLINECOLOR 32 32 32
END
END # States polygon layer ends here
# End of LAYER DEFINITIONS -------------------------------
END # end of map file/object
Any help will be appreciated . I am not able to proceed further ..
With regards and thanks in advance
Dharani Babu S
_________________________________________________________________
Easiest Money Transfer to India. Send Money To 6000 Indian Towns.
http://go.msnserver.com/IN/42198.asp Easiest Way To Send Money Home!
