[Mapserver-users] epsg error ! help me !
Palle Due Larsen
palle at mail-online.dk
Wed Mar 31 04:31:38 EST 2004
Have you set the PROJLIB environment variable?
Best regards
Palle Due Larsen
Carl Bro GIS&IT
-----Original Message-----
To: mapserver-users at lists.gis.umn.edu
Date: Wed, 31 Mar 2004 12:50:09 +0530
Subject: [Mapserver-users] epsg error ! help me !
> Hi all
> I am using both ms4w package and also IIS version of the map server
> . I
> found a rather strange problem . I am working with examples on the
> map
> server tutorial to know deep about the way CGI variables work ...
> I am trying to render a simple shape file layer by passing the CGI
> variable
> from url without template html
> http://localhost/cgi-bin/mapserv_40.exe?map=C:/ms4w/Apache/htdocs/dem
> of/example1-1.map&mode=map
> in the ms4w apache package and also in IIS based package like this
> http://localhost/cgi-bin/mapserv_40.exe?map=C:/Inetpub/wwwroot/iisdem
> o/example1-1.map&mode=map
> But I got the following errors in ms4w package trials ...
> msProcessProjection(): Projection library error. no options found in
> 'init'
> file
> and the following in IIS based trails
> msProcessProjection(): init:epsg:4376 error ..
> why so ? I checked the C:/ms4w/proj/epsg and found the line 4376
> ...the same
> I found at
> C:/proj for IIS...but both the file sizes differ ( ms4w epsg file
> size is
> around 190 kb whereas file size of C:/Proj of IIS version is 300kb )
> and but
> still I dont know why I have this error ...
> This is the map file used in example 1 ...
> MAP
> IMAGETYPE PNG
> EXTENT 201621.496941 -294488.285333 1425518.020722
> 498254.511514
> SIZE 400 300
> SHAPEPATH "data1/data"
> IMAGECOLOR 255 255 255
> PROJECTION
> #"proj=laea"
> # "ellps=clrk66"
> # "lat_0=45"
> # "lon_0=-100"
> # Alternatively, you can specify an EPSG code.
> # "init=epsg:2163"
> END
> # Start of LAYER DEFINITIONS
> LAYER # States polygon layer begins here
> NAME states
> DATA states_ugl
> STATUS DEFAULT
> TYPE POLYGON
> PROJECTION
> "init=epsg:4376"
> END
> CLASS
> COLOR 232 232 232
> OUTLINECOLOR 32 32 32
> END
> END # States polygon layer ends here
> # End of LAYER DEFINITIONS -------------------------------
> END # end of map file/object
> Any help will be appreciated . I am not able to proceed further ..
> With regards and thanks in advance
> Dharani Babu S
> _________________________________________________________________
> Easiest Money Transfer to India. Send Money To 6000 Indian Towns.
> http://go.msnserver.com/IN/42198.asp Easiest Way To Send Money Home!
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
