[Mapserver-users] epsg error ! help me !
Pericles Nacionales
nacional at cbs.umn.edu
Wed Mar 31 09:48:06 EST 2004
Copy the epsg file from your ms4w directory to your proj directory (don't
forget to rename the original) and it should work. The message tells you
that the projection you're trying to use isn't defined in the epsg file.
By default, proj looks for the epsg file under c:\proj\nad. So, by
copying the epsg file from your ms4w directory to c:\proj\nad, your
application should now work. Alternative, you can create a new system
variable called "PROJ_LIB" and point it to your ms4w epsg directory.
If you want to confirm that you don't have the projection definition on
one of those epsg files. Open them using a text editor (they're just text
files) and search for your epsg code. You can also just append this
messing definition to your default epsg file.
I hope that helps.
-Perry
On Wed, 31 Mar 2004, Dharani Babu wrote:
> Hi all
> I am using both ms4w package and also IIS version of the map server . I
> found a rather strange problem . I am working with examples on the map
> server tutorial to know deep about the way CGI variables work ...
> I am trying to render a simple shape file layer by passing the CGI variable
> from url without template html
> http://localhost/cgi-bin/mapserv_40.exe?map=C:/ms4w/Apache/htdocs/demof/example1-1.map&mode=map
> in the ms4w apache package and also in IIS based package like this
> http://localhost/cgi-bin/mapserv_40.exe?map=C:/Inetpub/wwwroot/iisdemo/example1-1.map&mode=map
> But I got the following errors in ms4w package trials ...
> msProcessProjection(): Projection library error. no options found in 'init'
> file
> and the following in IIS based trails
> msProcessProjection(): init:epsg:4376 error ..
> why so ? I checked the C:/ms4w/proj/epsg and found the line 4376 ...the same
> I found at
> C:/proj for IIS...but both the file sizes differ ( ms4w epsg file size is
> around 190 kb whereas file size of C:/Proj of IIS version is 300kb ) and but
> still I dont know why I have this error ...
> This is the map file used in example 1 ...
> MAP
> IMAGETYPE PNG
> EXTENT 201621.496941 -294488.285333 1425518.020722 498254.511514
> SIZE 400 300
> SHAPEPATH "data1/data"
> IMAGECOLOR 255 255 255
> PROJECTION
> #"proj=laea"
> # "ellps=clrk66"
> # "lat_0=45"
> # "lon_0=-100"
> # Alternatively, you can specify an EPSG code.
> # "init=epsg:2163"
> END
> # Start of LAYER DEFINITIONS ---------------------------------------------
> LAYER # States polygon layer begins here
> NAME states
> DATA states_ugl
> STATUS DEFAULT
> TYPE POLYGON
> PROJECTION
> "init=epsg:4376"
> END
> CLASS
> COLOR 232 232 232
> OUTLINECOLOR 32 32 32
> END
> END # States polygon layer ends here
> # End of LAYER DEFINITIONS -------------------------------
> END # end of map file/object
> Any help will be appreciated . I am not able to proceed further ..
> With regards and thanks in advance
> Dharani Babu S
> _________________________________________________________________
> Easiest Money Transfer to India. Send Money To 6000 Indian Towns.
> http://go.msnserver.com/IN/42198.asp Easiest Way To Send Money Home!
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
