[Mapserver-users] Seg fault with labels
Paco Regodon
mapserver at meteologica.es
Mon May 3 14:18:18 EDT 2004
I had a similar problem and solved it using "LABELCACHE OFF".
Hope it helps.
Paco
On Monday 03 May 2004 18:22, Matt Hatcher wrote:
> Hi all,
> I'm running Mapserver 4.0.2 on Mandrake Linux 9.2. It was built with the
> help of the redhat 9 guide in the wiki. Thanks to the guy who put that
> together!
> I'm having problems with labelling layers. Mapserver works beautifully
> providing I don't try to use labels. If I do (either using bitmap or
> truetype), I get Internal Server Error. Running the query at the command
> line using the QUERY_STRING debug, I get a seg fault.
> This suggests to me a problem with my freetype or gd libraries - I'm using:
> freetype-1.3.1-20mdk.rpm, libfreetype6-2.1.4-6mdk and gd-2.0.15
> My mapserv -v is:
> MapServer version 4.0.2 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF
> SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=JPEG INPUT=POSTGIS INPUT=OGR
> INPUT=GDAL INPUT=SHAPEFILE
> I've tried to run ./configure without freetype, but it still compiles the
> libraries in and I get the same result.
> Anybody got any bright ideas?!
> Thanks in advance
> Matt.
> -----Original Message-----
> From: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of
> mapserver-users-request at lists.gis.umn.edu
> Sent: 02 May 2004 18:00
> To: mapserver-users at lists.gis.umn.edu
> Subject: Mapserver-users digest, Vol 1 #509 - 9 msgs
> Send Mapserver-users mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Mapserver-users digest..."
> Today's Topics:
> 1. RE: world files and tile indexing (Ed McNierney)
> 2. Re: Shapelib, GPC, PHP, and polygon clipping (Frank Warmerdam)
> 3. Re: arcgrid to ascii(etc) (Frank Warmerdam)
> 4. Looking for reference links and online MapServer/MapScript Forum
> (Mike Juvrud)
> 5. Re: Looking for reference links and online MapServer/MapScript Forum
> (Eduardo Patto Kanegae)
> 6. RE: [postgis-users] RE: gone are my query results (Charlton Purvis)
> 7. RE: [postgis-users] RE: gone are my query results (Gregory S.
> Williamson)
> 8. RE: [postgis-users] RE: gone are my query results (Charlton Purvis)
> 9. Re: RE: [postgis-users] RE: gone are my query results (Paul Ramsey)
> --__--__--
> Message: 1
> Subject: RE: [Mapserver-users] world files and tile indexing
> Date: Sat, 1 May 2004 13:39:07 -0400
> From: "Ed McNierney" <ed at topozone.com>
> To: "Antonio Cosenza" <antonio.cosenza at polito.it>,
> <mapserver-users at lists.gis.umn.edu>
> This is a multi-part message in MIME format.
> ------_=_NextPart_001_01C42FA3.3437712E
> Content-Type: text/plain;
> charset="us-ascii"
> Content-Transfer-Encoding: quoted-printable
> Antonio -
> =20
> Thanks - that is very helpful!
> =20
> Things seem fine, but you need to create georeference data for the
> images in a way that can be used - the JPG files could have world files
> (.JGW files) or the TIF files could have world files (.TFW) but you need
> them. You need to create these world files. You should try to read the
> coordinates from the shapefile (use shpdump) and you need to calculate
> the values for the world files. With only three files you can
> relatively easily do this by hand.
> =20
> The shapefile polygons should give you the upper-left corner coordinate
> of each tile, and you should be able to calculate the size of each pixel
> in X and Y units from the shapefile polygons and information about how
> many pixels wide and high each image is (use tiffinfo).
> =20
> - Ed
> Ed McNierney
> President and Chief Mapmaker
> TopoZone.com / Maps a la carte, Inc.
> 73 Princeton Street, Suite 305
> North Chelmsford, MA 01863
> ed at topozone.com
> (978) 251-4242=20
> _____ =20
> From: Antonio Cosenza [mailto:antonio.cosenza at polito.it]=20
> Sent: Saturday, May 01, 2004 6:18 AM
> Subject: Re: [Mapserver-users] world files and tile indexing
> It would help if you could explain what you're trying to do! =20
> ok, i'll try tou explain you my situation!
> What
> format are the raster files in now,=20
> The raster files are in jpg format. They are a set of 3 tiles NOT
> GEOREFERENCED (of course, they are jpg!). But, i have a shapefile,
> called tile.shp (so, georeferenced) representing the footprints of the
> tiles. In tile.shp, I created a field (Path) including the absoulte path
> to tiff tiles on my disk (ex. /var/www/.....F4-C4.tif).Now, i converted
> the jpg files in tiff files, without the world files. I use this mapfile
> configuration:
> LAYER
> NAME "pannelli"
> STATUS ON
> TYPE RASTER
> TILEINDEX "./tile.shp"
> TILEITEM "Path"
> END
> I run maplab, but an error occurs: unable to open tiff files:
> Description=09
> Unable to open world file for reading. in
> /maplab/htdocs/common/wrapper/drawmap.php=09
> Failed to draw layer named 'pannelli'. in
> So, i created some empty world files! This time, maplab runs without
> error, but it doesn't show me the tiles. It shows me only a blank page.
> Where is the problem?
> and what geographic reference data
> do you have for them (and in what format)?
> =09
> - Ed
> =09
> Ed McNierney
> ed at topozone.com
> (978) 251-4242 =20
> =09
> Sent: Friday, April 30, 2004 5:43 AM
> To: Ed McNierney; mapserver-users at lists.gis.umn.edu
> =09
> so, i need to convert the raster tiles in tiff format, without
> world
> files? Right?
> =09
> thanks
> =09
> Ed McNierney wrote:
> =09
> =20
> Antonio -
> =09
> Yes, as long as the georeference information is there
> for the tile=20
> index to be created (and for the image to be rendered
> properly). =20
> GeoTIFFs can be used in a TILEINDEX layer without world
> files.
> =09
> - Ed
> =09
> Ed McNierney
> ed at topozone.com
> (978) 251-4242
> =09
> Sent: Thursday, April 29, 2004 2:40 PM
> Subject: [Mapserver-users] world files and tile indexing
> =09
> Hi everyvody,
> is it possible to use tile indexing without world file?
> =09
> thanks
> Mapserver-users at lists.gis.umn.edu
> =09
> =09
> =09
> =20
> =09
> =20
> =09
> =09
> =09
> =09
> =20
> Content-Type: text/html;
> charset="us-ascii"
> <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
> <HTML><HEAD><TITLE></TITLE>
> <META http-equiv=3DContent-Type content=3D"text/html; =
> charset=3Dus-ascii">
> <META content=3D"MSHTML 6.00.2800.1400" name=3DGENERATOR></HEAD>
> <BODY text=3D#000000 bgColor=3D#ffffff>
> <DIV dir=3Dltr align=3Dleft><SPAN class=3D456053617-01052004><FONT =
> face=3DArial=20
> color=3D#0000ff size=3D2>Antonio -</FONT></SPAN></DIV>
> face=3DArial=20
> color=3D#0000ff size=3D2></FONT></SPAN> </DIV>
> face=3DArial=20
> color=3D#0000ff size=3D2>Thanks - that is very =
> helpful!</FONT></SPAN></DIV>
> face=3DArial=20
> face=3DArial=20
> color=3D#0000ff size=3D2>Things seem fine, but you need to create =
> georeference data=20
> for the images in a way that can be used - the JPG files could have =
> world files=20
> (.JGW files) or the TIF files could have world files (.TFW) but you need =
> them. You need to create these world files. You should try =
> to read=20
> the coordinates from the shapefile (use shpdump) and you need to =
> calculate the=20
> values for the world files. With only three files you can =
> relatively=20
> easily do this by hand.</FONT></SPAN></DIV>
> face=3DArial=20
> face=3DArial=20
> color=3D#0000ff size=3D2>The shapefile polygons should give you the =
> upper-left=20
> corner coordinate of each tile, and you should be able to calculate the =
> size of=20
> each pixel in X and Y units from the shapefile polygons and information =
> about=20
> how many pixels wide and high each image is (use =
> tiffinfo).</FONT></SPAN></DIV>
> face=3DArial=20
> <DIV dir=3Dltr align=3Dleft><SPAN =
> class=3D456053617-01052004> <FONT=20
> face=3DArial color=3D#0000ff size=3D2>- Ed</FONT></SPAN></DIV>
> <P><FONT size=3D2>Ed McNierney<BR>President and Chief =
> Mapmaker<BR>TopoZone.com /=20
> Maps a la carte, Inc.<BR>73 Princeton Street, Suite 305<BR>North =
> Chelmsford,=20
> MA 01863<BR>ed at topozone.com<BR>(978) 251-4242 =
> </FONT></P></SPAN></DIV><BR>
> <DIV class=3DOutlookMessageHeader lang=3Den-us dir=3Dltr align=3Dleft>
> <HR tabIndex=3D-1>
> <FONT face=3DTahoma size=3D2><B>From:</B> Antonio Cosenza=20
> [mailto:antonio.cosenza at polito.it] <BR><B>Sent:</B> Saturday, May 01, =
> 2004 6:18=20
> AM<BR><B>To:</B> mapserver-users at lists.gis.umn.edu<BR><B>Subject:</B> =
> Re:=20
> [Mapserver-users] world files and tile indexing<BR></FONT><BR></DIV>
> <DIV></DIV><BR>
> <BLOCKQUOTE =
> cite=3Dmid13858AA1A74F30419F319ACB66A9D1224E4426 at mercator.topozone.com=20
> type=3D"cite"><PRE wrap=3D"">It would help if you could explain what =
> you're trying to do! </PRE></BLOCKQUOTE>ok,=20
> i'll try tou explain you my situation!<BR>
> <BLOCKQUOTE =
> type=3D"cite"><PRE wrap=3D"">What
> format are the raster files in now, </PRE></BLOCKQUOTE>The raster files =
> are in=20
> jpg format. They are a set of 3 tiles NOT GEOREFERENCED (of =
> course, they=20
> are jpg!). But, i have a shapefile, called tile.shp (so, georeferenced)=20
> representing the footprints of the tiles. In tile.shp, I created a =
> field=20
> (Path) including the absoulte path to tiff tiles on my disk (ex.=20
> /var/www/.....F4-C4.tif).Now, i converted the jpg files in tiff =
> files,=20
> without the world files. I use this mapfile=20
> configuration:<BR><BR> LAYER<BR> NAME=20
> "pannelli"<BR> STATUS ON<BR> TYPE=20
> RASTER<BR> TILEINDEX =
> "./tile.shp"<BR> =20
> TILEITEM "Path"<BR> END<BR><BR>I run maplab, but an error occurs: =
> unable=20
> to open tiff files:<BR><BR>
> <TABLE cellSpacing=3D0 cellPadding=3D2 border=3D0>
> <TBODY>
> <TR>
> <TD colSpan=3D2><FONT face=3DArial,Helvetica,sans-serif =
> color=3D#000000=20
> size=3D2>Description</FONT></TD></TR>
> <TR>
> <TD colSpan=3D2><FONT face=3DARIAL,Helvetica,sans-serif =
> color=3D#ff3333=20
> size=3D2>Unable to open world file for reading. in=20
> /maplab/htdocs/common/wrapper/drawmap.php</FONT></TD></TR>
> <TR>
> color=3D#ff3333=20
> size=3D2>Failed to draw layer named 'pannelli'. in=20
> <TR>
> color=3D#ff3333=20
> <TR>
> color=3D#ff3333=20
> /maplab/htdocs/common/wrapper/drawmap.php</FONT></TD></TR></TBODY></TABLE=
> ><BR>So,=20
> i created some empty world files! This time, maplab runs without error, =
> but it=20
> doesn't show me the tiles. It shows me only a blank page.<BR>Where is =
> the=20
> problem?<BR><BR><BR>
> <BLOCKQUOTE =
> type=3D"cite"><PRE wrap=3D"">and what geographic reference data
> - Ed
> Ed McNierney
> <A class=3Dmoz-txt-link-abbreviated =
> href=3D"mailto:ed at topozone.com">ed at topozone.com</A>
> (978) 251-4242 =20
> From: Antonio Cosenza [<A class=3Dmoz-txt-link-freetext =
> href=3D"mailto:antonio.cosenza at polito.it">mailto:antonio.cosenza at polito.i=
> t</A>]=20
> To: Ed McNierney; <A class=3Dmoz-txt-link-abbreviated =
> href=3D"mailto:mapserver-users at lists.gis.umn.edu">mapserver-users at lists.g=
> is.umn.edu</A>
> so, i need to convert the raster tiles in tiff format, without world
> files? Right?
> thanks
> Ed McNierney wrote:
> </PRE>
> <BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Antonio -
> Yes, as long as the georeference information is there for the tile=20
> index to be created (and for the image to be rendered properly). =20
> GeoTIFFs can be used in a TILEINDEX layer without world files.
> - Ed
> Ed McNierney
> (978) 251-4242
> t</A>]
> To: <A class=3Dmoz-txt-link-abbreviated =
> is.umn.edu</A>
> Hi everyvody,
> thanks
> href=3D"mailto:Mapserver-users at lists.gis.umn.edu">Mapserver-users at lists.g=
> is.umn.edu</A>
> href=3D"http://lists.gis.umn.edu/mailman/listinfo/mapserver-users">http:/=
> /lists.gis.umn.edu/mailman/listinfo/mapserver-users</A>
> =20
> </PRE></BLOCKQUOTE><PRE wrap=3D""><!---->
> is.umn.edu</A>
> </PRE></BLOCKQUOTE><BR></BODY></HTML>
> ------_=_NextPart_001_01C42FA3.3437712E--
> --__--__--
> Message: 2
> Date: Sat, 01 May 2004 15:03:03 -0400
> From: Frank Warmerdam <warmerdam at pobox.com>
> To: "Ryan, Adam" <ARyan at co.linn.or.us>
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] Shapelib, GPC, PHP, and polygon clipping
> Ryan, Adam wrote:
> > Steve, Frank, etc...
> > A while back Steve Lime wrote in response to a request for polygon
> clipping
> > code.
> http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0201/msg00094.html
> > He suggested using the GPC library. I checked this out and was able to
> get
> > it to work.
> > Is it worth trying to use GPC with either PHP mapscript or shapelib
> directly
> > and write a little routine to grab the shapes in question, convert them
> to
> > gpc ascii format, run the clip operation, and convert back to a shapefile
> > result? In PHP I could build the ASCII files, then call a gpc
> > executable, and then translate the ASCII result back into a new
> > shapefile.
> > Am I exploring old technology? Is there a better way? Seems like a lot
> of
> > steps but all the really hard work has been done and it's just a matter
> > of reformatting data to work with the different tools.
> Adam,
> Invoking GPC externally via an ascii file interface may be too slow
> depending
> on your needs but it is certainly doable.
> From a more general point of view, it is my hope to interface the GEOS
> library (http://geos.refractions.net) with OGR at some point with a
> convenient
> mechanism to convert OGR geometries into a form usable in GEOS. So from my
> point of view a GEOS is the "future" of complex geometry operations in
> OGR (and indirectly shapelib). In fact, I would like to see a nice SWIG'ed
> interface to GEOS so that it can be easily used in most/all of the
> mapscript supported languages.
> GEOS is the library used by PostGIS for geometry operations, but it is
> independent of PostGIS. I think it does more than GPC. I was also slightly
> soured on GPC because of problematic licensing issues as I recall.
> So, if you have a particular need that is satisfied by passing geometries
> to GPC then by all means go ahead. However, I don't forsee it as being of
> strategic value. If you are interested in cooperating on swigged
> interfaces for GEOS and closer integration with OGR, Shapelib or MapServer
> geometries then perhaps we could get something going. I hadn't really been
> intending to get started on this yet though, so you might get stuck doing
> quite a bit of the heavy lifting.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> --__--__--
> Message: 3
> Date: Sat, 01 May 2004 15:17:56 -0400
> To: "Jason M. Nielsen" <jnielsen at aero-graphics.com>
> Subject: Re: [Mapserver-users] arcgrid to ascii(etc)
> Jason M. Nielsen wrote:
> > Anyone know of software that can convert arcgrid .adf files to ascii?
> Jason,
> GDAL read Arc/Info binary grid files in .adf format and can export a
> variety of formats including Arc/Info ASCII Grid format which is ... ASCII.
> eg.
> gdal_translate -of AAIGrid in_cov/w001001.adf out.grd
> Best regards,
> --__--__--
> Message: 4
> From: "Mike Juvrud" <ljuvrud at info-link.net>
> To: <mapserver-users at lists.gis.umn.edu>
> Date: Sat, 1 May 2004 18:23:21 -0500
> Subject: [Mapserver-users] Looking for reference links and online
> I'm a MapServer/PHP MapScript newbie, looking for online reference
> materials, resources, sample code, etc. (beginner to advanced)...I would
> appreciate links to anything you might recommend. (english or deutsch)
> (I have already downloaded and gone through the tutorials, references,
> samples available on the mapserver & mapscript site.)
> Also - Is there a Mapserver/Mapscript forum/bulletin board online?
> Will sum,
> Mike Juvrud
> --__--__--
> Message: 5
> From: "Eduardo Patto Kanegae" <eduardo at consultoria.eti.br>
> Date: Sat, 1 May 2004 23:58:10 -0300
> To: "Mike Juvrud" <ljuvrud at info-link.net>
> CC: mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] Looking for reference links and online
> at the official website , section Documentation, u will find all u're
> looking for...
> for deutsch reference , take a look at www.mapmedia.de ... i think they
> have a book about mapserver.
> http://www.consultoria.eti.br
> UIN: 303747254
> I Encontro Nacional de Usuários MapServer -
> http://mapserver.cttmar.univali.br/encontro2004
> Projeto MapServer Brasil - http://mapserver.cttmar.univali.br
> ***Fim da Mensagem / End of Message ***
> On Sat, 1 May 2004 18:23:21 -0500, "Mike Juvrud" <ljuvrud at info-link.net>
> escreveu:
> > De: "Mike Juvrud" <ljuvrud at info-link.net>
> > Data: Sat, 1 May 2004 18:23:21 -0500
> > Para: <mapserver-users at lists.gis.umn.edu>
> > Assunto: [Mapserver-users] Looking for reference links and online
> > Will sum,
> > Mike Juvrud
> --__--__--
> Message: 6
> Date: Sat, 1 May 2004 22:59:22 -0400
> From: "Charlton Purvis" <cpurvis at asg.sc.edu>
> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>,
> Subject: [Mapserver-users] RE: [postgis-users] RE: gone are my query
> results
> Thanks for your reply, Gregory. I'm forwarding this onto the MS folks to
> see if they have any pearls of wisdom.
> Everything looks great in the db. If I render a map, I see all the points
> correctly. If I take that query and plug it in to the command line, I see
> the rows. But the moment I try to do either a cgi query, WFS query, or a
> PHP query, I get nothing back. No error message.
> I'm actually getting panicky which isn't any fun. Has anyone seen anything
> like this before?
> Queries rely on OID's and SRID's. Is there any way they could have gotten
> mucked up? Can I somehow refresh them?
> Thanks,
> Charlton
> From: Gregory S. Williamson [mailto:gsw at globexplorer.com]
> Sent: Sat 5/1/2004 6:20 PM
> To: PostGIS Users Discussion
> Cc:
> Subject: [postgis-users] RE: gone are my query results
> If you do the query directly to postgres (via psql or pgAdmin or whatever)
> does the query return results ?
> If so, then my guess is that this is not a database error, at least not
> directly. If ot then yes, it would seem that somehow the postGIS itself has
> gottent snarfled.
> The change you made relating the geometryColumns doesn't sound to me like
> it should effect queries unless somehow the SRID info for the tables in
> your mapserver queries got clobbered; should be easy enough to confirm that
> this data is ok.
> I am not familiar enough with PHP and mapserver to have a clue; does the
> mapserver log itself show anything ?
> Not much help, I'm afraid, but perhaps posting this to the MMS list would
> add some more knowledge to the issue at hand ?
> Greg Williamson
> DBA
> GlobeXplorer LLC
> From: Charlton Purvis on behalf of Charlton Purvis
> Sent: Sat 5/1/2004 2:46 PM
> Cc:
> Subject: gone are my query results
> Hi, folks:
> Bizarre and unnerving problem here.
> Up until last night, mapping was fine and point-query was fine. Now it
> appears that the mapping is still great, but the point query and WFS are
> toast. I don't get any errors in pgsql.log or php.log. I get . . .
> nothing. Even going mapserv cgi query returns empty for a query I know
> should work.
> Maybe I'm being taught a lesson. In a separate database, I noticed that
> addgeometrycolumn was taking too long -- I create about 400 smaller tables
> per day. So I commented out fix_geometry_columns(); from the
> addgeometrycolumn function and did it once I had finished creating all my
> new tables. So am I paying the price? Has this corrupted this database as
> well as my other?
> If all this is OID stuff, is there any way to refresh all OID's?
> Restarted . . . yes. VACUUM and ANALYZE'd . . . yes.
> Thanks,
> Charlton
> postgis-users mailing list
> --__--__--
> Message: 7
> Date: Sat, 1 May 2004 20:11:41 -0700
> From: "Gregory S. Williamson" <gsw at globexplorer.com>
> results
> If you turn on the logging of statements in postgres and run the mapserver
> side of things, does the query show up in the logs ?
> If the query does not appear then I'd suspect networking or permissions or
> some darn thing keeping postgres from ever seeing the query.
> It it does show up then maybe the problem is in the return trip to MS or in
> the processing of that data (perhaps your OID suspicions), since it sounds
> as if the query itself can be processed.
> Any changes to *anything* on either server and anything in between ? (not
> likely but always worth ruling out)
> Or, shot in the dark, something messing with TOLERANCE so no points are
> selected in a query ?
> Very puzzling, I agree.
> Greg W.
> Sent: Sat 5/1/2004 7:59 PM
> To: PostGIS Users Discussion; mapserver-users at lists.gis.umn.edu
> Cc:
> Subject: RE: [postgis-users] RE: gone are my query results
> like this before?
> Thanks,
> Charlton
> Cc:
> gottent snarfled.
> this data is ok.
> Greg Williamson
> DBA
> GlobeXplorer LLC
> Cc:
> Hi, folks:
> should work.
> well as my other?
> Thanks,
> Charlton
> --__--__--
> Message: 8
> Date: Sat, 1 May 2004 23:42:34 -0400
> results
> OK, Greg, I think we might be onto something. But it still looks very
> grim.
> I turned on all the logging, and I notice that MS sends it this query:
> LOCATION: pg_parse_query, postgres.c:464
> LOG: 00000: statement: DECLARE mycursor BINARY CURSOR FOR SELECT
> temperature_celcius::text,asbinary(force_collection(force_2d(the_geom)),'ND
>R '),OID::text from sst_map WHERE (date_trunc('hour',report_time_stamp +
> interval '1 hour' * -04) = date_trunc('hour',timestamp without time zone
> '2004-05-01 22:00:00') and (label_z <= 5 or label_z is null)) and (the_geom
> && setSRID( 'BOX3D(-83.0454044480208 24.3838940085927,-82.6541628156105
> 24.775135641003)'::BOX3D,find_srid('','sst_map','the_geom') ))
> OK. That's good. Because if I stick the SELECT part at a psql prompt, I
> get back the row I want. And I also notice that its OID is 2185295089.
> But if I look at the last sql statement in the log, it's another cursor,
> but the OID is wrong.
> station_id::text,time_stamp::text,z::text,label_z::text,temperature_celcius:
> :text,temperature_fahrenheit::text,value_temperature_celcius::text,value_te
> :m
> perature_fahrenheit::text,lon::text,lat::text,title::text,institution::text
> institution_url::text,institution_dods_url::text,source::text,refs::text,co
>n
> tact::text,report_time_stamp::text,asbinary(force_collection(force_2d(the_g
>e om)),'NDR') from sst_map WHERE OID = 2147483647
> So had they kept the OID, I would be in good shape.
> This isn't looking good!!!
> Charlton
> Sent: Sat 5/1/2004 11:11 PM
> Cc:
> in the processing of that data (perhaps your OID suspicions), since it
> sounds as if the query itself can be processed.
> Greg W.
> Cc:
> anything like this before?
> Thanks,
> Charlton
> Cc:
> gottent snarfled.
> this data is ok.
> Greg Williamson
> DBA
> GlobeXplorer LLC
> Cc:
> Hi, folks:
> should work.
> well as my other?
> Thanks,
> Charlton
> --__--__--
> Message: 9
> Date: Sat, 01 May 2004 21:08:54 -0700
> From: Paul Ramsey <pramsey at refractions.net>
> Subject: Re: [Mapserver-users] RE: [postgis-users] RE: gone are my query
> results
> To: Charlton Purvis <cpurvis at asg.sc.edu>
> Cc: PostGIS Users Discussion <postgis-users at postgis.refractions.net>,
> Got your back, Charlton :)
> The problem is that your PostgreSQL oids are larger than the mapserver
> row number variable can store. The oid is larger than a signed 32 bit
> integer can store.
> So, solution.
> Do not use oid as your "unique" field. Make use of the "using unique"
> clause in your data statement, and reference a different unique field
> in your table. Make sure that field is indexed. If you have loaded your
> data with shp2pgsql, you probably have a 'gid' field you can use that
> is a primary key (and therefore already indexed).
> Yours,
> Paul
> > grim.
> > ,'NDR'),OID::text from sst_map WHERE
> > (date_trunc('hour',report_time_stamp + interval '1 hour' * -04) =
> > date_trunc('hour',timestamp without time zone '2004-05-01 22:00:00')
> > and (label_z <= 5 or label_z is null)) and (the_geom && setSRID(
> > prompt, I get back the row I want. And I also notice that its OID is
> > 2185295089.
> > cursor, but the OID is wrong.
> > cius::text,temperature_fahrenheit::text,value_temperature_celcius::text
> > ,value_temperature_fahrenheit::text,lon::text,lat::text,title::text,ins
> > titution::text,institution_url::text,institution_dods_url::text,source:
> > :text,refs::text,contact::text,report_time_stamp::text,asbinary(force_c
> > ollection(force_2d(the_geom)),'NDR') from sst_map WHERE OID =
> > 2147483647
> > Charlton
> > Cc:
> > mapserver side of things, does the query show up in the logs ?
> > permissions or some darn thing keeping postgres from ever seeing the
> > query.
> > or in the processing of that data (perhaps your OID suspicions), since
> > it sounds as if the query itself can be processed.
> > (not likely but always worth ruling out)
> > are selected in a query ?
> > Greg W.
> > Cc:
> > folks to see if they have any pearls of wisdom.
> > points correctly. If I take that query and plug it in to the command
> > line, I see the rows. But the moment I try to do either a cgi query,
> > WFS query, or a PHP query, I get nothing back. No error message.
> > gotten mucked up? Can I somehow refresh them?
> > Thanks,
> > Charlton
> > Cc:
> > whatever) does the query return results ?
> > not directly. If ot then yes, it would seem that somehow the postGIS
> > itself has gottent snarfled.
> > like it should effect queries unless somehow the SRID info for the
> > tables in your mapserver queries got clobbered; should be easy enough
> > to confirm that this data is ok.
> > the mapserver log itself show anything ?
> > would add some more knowledge to the issue at hand ?
> > Greg Williamson
> > DBA
> > GlobeXplorer LLC
> > Cc:
> > Hi, folks:
> > it appears that the mapping is still great, but the point query and
> > WFS are toast. I don't get any errors in pgsql.log or php.log. I get
> > . . . nothing. Even going mapserv cgi query returns empty for a query
> > I know should work.
> > that addgeometrycolumn was taking too long -- I create about 400
> > smaller tables per day. So I commented out fix_geometry_columns();
> > from the addgeometrycolumn function and did it once I had finished
> > creating all my new tables. So am I paying the price? Has this
> > corrupted this database as well as my other?
> > Thanks,
> > Charlton
> Paul Ramsey
> Refractions Research
> Email: pramsey at refractions.net
> Phone: (250) 885-0632
> --__--__--
> End of Mapserver-users Digest
