[Mapserver-users] Coloring Problem
Norbert Thieme
norbert.thieme at ilmenau.baw.de
Tue May 4 03:23:07 EDT 2004
Sam Choudry schrieb:
> Hello,
> Here is the same old problem still not solved. I want to change the
> color of my area layer "nal-blk" according to user input. For that I am
> using the code:
> if($r!='' && $g!='' && $b!='')
> $layer = $map->getlayerbyname("nal-blks");
> $class = $layer->getclass(0);
> $layer->open($map->shapepath);
> $index = findindex($r,$g,$b);
> $class->set('color',index);
> I am using a function I received from one of the list members,
> function findindex($r,$g,$b)
> GLOBAL $map;
> $r1=(int) $r;
> $g1=(int) $g;
> $b1=(int) $b;
> for($i=-10;$i<0;$i++)
> $col=$map->getColorByIndex($i);
> $tr=$col->red;
> $tg=$col->green;
> $tb=$col->blue;
> if(($r1 == $tr) && ($g1 == $tg) && ($b1 == $tb))
> $in=$i;
> break;
> $in=$in+1;
> return($in);
> The Error message are :
> Warning: Wrong parameter count for open() in
> c:\inetpub\wwwroot\php\nalbari.php on line 21
The layer->open() function don't except any paramters I think so simply
leave it empty.
> Fatal error: Property 'color' does not exist in this object.
> in c:\inetpub\wwwroot\php\nalbari.php on line 23
The next message say that there is no color in the class-object. So you
can't change it and I just had a look in the mapscript docs - there seem
to be no color-object. If I don't have missed something there will be no
way to change that but I think there should be one.
I hope someone more experienced knows a workaround or can point us to
the right objects/functions or docs.
Regards,
Norbert
> The Map File snippet is also provided:
> LAYER #DISTRICT BLOCKS#
> NAME "nal-blks"
> DATA nal-blks
> STATUS ON
> TYPE POLYGON
> CLASS
> NAME '0'
> COLOR 219 250 253
> OUTLINECOLOR 154 181 250
> END
> END
> What can be the possile solution to this? Regards,
> Samuzzal
> _____________________________________________________________
> Linux.Net -->Open Source to everyone
> Powered by Linare Corporation
> http://www.linare.com/
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
