[Mapserver-users] Coloring Problem
Norbert Thieme
norbert.thieme at ilmenau.baw.de
Tue May 4 09:37:05 EDT 2004
Norbert Thieme schrieb:
> Sam Choudry schrieb:
>> Hello,
>> Here is the same old problem still not solved. I want to change the
>> color of my area layer "nal-blk" according to user input. For that I am
>> using the code:
>> if($r!='' && $g!='' && $b!='')
>> $layer = $map->getlayerbyname("nal-blks");
>> $class = $layer->getclass(0);
>> $layer->open($map->shapepath);
>> $index = findindex($r,$g,$b);
>> $class->set('color',index);
>> I am using a function I received from one of the list members,
>> function findindex($r,$g,$b)
>> GLOBAL $map;
>> $r1=(int) $r;
>> $g1=(int) $g;
>> $b1=(int) $b;
>> for($i=-10;$i<0;$i++)
>> $col=$map->getColorByIndex($i);
>> $tr=$col->red;
>> $tg=$col->green;
>> $tb=$col->blue;
>> if(($r1 == $tr) && ($g1 == $tg) && ($b1 == $tb))
>> $in=$i;
>> break; } }
>> $in=$in+1;
>> return($in);
>> The Error message are :
>> Warning: Wrong parameter count for open() in
>> c:\inetpub\wwwroot\php\nalbari.php on line 21
> Hi,
> The layer->open() function don't except any paramters I think so simply
> leave it empty.
>> Fatal error: Property 'color' does not exist in this object.
>> in c:\inetpub\wwwroot\php\nalbari.php on line 23
> The next message say that there is no color in the class-object. So you
> can't change it and I just had a look in the mapscript docs - there seem
> to be no color-object. If I don't have missed something there will be no
> way to change that but I think there should be one.
> I hope someone more experienced knows a workaround or can point us to
> the right objects/functions or docs.
> Regards,
> Norbert
>> The Map File snippet is also provided:
>> LAYER #DISTRICT BLOCKS#
>> NAME "nal-blks"
>> DATA nal-blks
>> STATUS ON
>> TYPE POLYGON
>> CLASS
>> NAME '0'
>> COLOR 219 250 253
>> OUTLINECOLOR 154 181 250
>> END
>> END
>> What can be the possile solution to this? Regards,
>> Samuzzal
>> _____________________________________________________________
>> Linux.Net -->Open Source to everyone
>> Powered by Linare Corporation
>> http://www.linare.com/
>> Mapserver-users mailing list
>> Mapserver-users at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
sorry I was wrong. It was in the docs I only looked on the wrong point.
This is the way to go:
$addlyr_layer = ms_newLayerObj($map);
$addlyr_layer->set(status, MS_ON);
$addlyr_layer->set(name, $addlyr_file);
$addlyr_layer->set(data, $addlyr_string);
$addlyr_layer->set(type, 1);
$addlyr_class = ms_newClassObj($addlyr_layer);
$addlyr_class->set(name, "Class");
$addlyr_style = ms_newStyleObj($addlyr_class);
$addlyr_style->color->setRGB(10, 100, 10);
$image=$map->draw();
$image_url = $image->saveWebImage();
Regards,
Norbert
