[Mapserver-users] PostGIS and CLass - Expression Help
Simpson, Andrew
Andrew.Simpson at ssc.nasa.gov
Tue May 4 09:19:14 EDT 2004
Probably not the problem, but your CLASSITEM is "item_x" and your EXPRESSION
has [item_y].
-----Original Message-----
Sent: Tuesday, May 04, 2004 4:57 AM
To: mapserverlist
Subject: [Mapserver-users] PostGIS and CLass - Expression Help
Dear list,
I'm stuck with making an expression on a postgis datasource (code see
below):
I get no error but also no labels at all - and there are labels, I'm
sure. I tried everything with quotations, capitalisation in my
expression, etc. but still get no results :-(.
NAME "xxx"
TYPE ANNOTATION
STATUS ON
CONNECTIONTYPE postgis
CONNECTION "user=admin dbname=datasrc host=localhost"
DATA "the_geom from (select * from view_x) as foo using unique item
using SRID=31493"
# viewx is a stored query in my database
METADATA
'WMS_SRS' 'epsg:31493'
'WMS_TITLE' 'xxx'
'WMS_FEATURE_INFO_MIME_TYPE' 'text/html'
END
PROJECTION
"init=epsg:31493"
END
CLASSITEM "item_x"
LABELITEM "label"
LABELANGLEITEM "angle"
CLASS
EXPRESSION ([item_y] > 1301) # /^13/
NAME "name"
LABEL
TYPE TRUETYPE
FONT 'arial'
SIZE 9
COLOR 0 0 0
END
END
When making sth. like 'EXPRESSION /^13/' I get results and see labels on
my map, but that's not enough for us. Maybe there's a problem because
the data does not result from a postgres table directly?
Any ideas, hints, similar problems out there?
Thanks very much in advance!
Till
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
