[Mapserver-users] Mozilla and Firefox
Michael Schulz
mschulz at webgis.de
Thu May 6 09:33:41 EDT 2004
i remember having similar problems with mozilla. Is mapserver returning
an error message?
I think my problem was solved by juggling around with the order of the
cgi parameter. Especially the map.x and map.y seem to be problematical.
There was a thread about this issue a while ago:
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0302/msg00638.html
If you use javascript to submit your form, make sure you have specified
the language attribute of the <script language="JavaScript"> tag. This
solved another problem with Gecko/Mozilla.
HTH, Michael
Micha Silver schrieb:
> I've set up my (first) map file and html template with zooms, and point
> query. Works as I expect using IE, but the zooming and querying *don't* work
> with Mozilla 1.6 nor with Firefox.
> I'm using mapserver 4.0.2 - no mapscript or anything fancy yet, just a few
> CGI variable substitutions in the html template: mapext, zoom, and toggling
> between browse mode and query mode.
> What needs to be done to get this working under Mozilla also?
> TIA
> --Micha
> Micha Silver
> Arava Development Co
> tel: (972) 08-6592270
> fax: (972) 03-5422508
> cell: 052-3665918
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Michael Schulz in medias res
Dipl.-Geologe Gesellschaft für
Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
0761 55695-95 (Fax 96)
mschulz at webgis.de www.webgis.de/www.zopecms.de
