[Mapserver-users] WMS server - client communication error
    Alexandros Chimarios
    alhim at intracom.gr
    Fri May  7 06:42:44 PDT 2004
Hello ,
 I  succesfully setup a WMS server using MapServer 4.2beta1, Apache 2 on a
Linux RH 9(2.4.20 kernel) pc. I tested my WMS server trough my browser and I
was able to see the image sent by the WMS.
Unfortunately when I tried to embed a layer of the WMS server into my Python
Mapscript based client testbed, I got the following error :
[Fri May  7 16:31:42 2004].514558 HTTP: Before download loop
[Fri May  7 16:31:42 2004].746877 msHTTPWriteFct(id=0, 4071 bytes)
[Fri May  7 16:31:42 2004].747725 msHTTPWriteFct(id=0, 4096 bytes)
[Fri May  7 16:31:42 2004].748155 msHTTPWriteFct(id=0, 3729 bytes)
[Fri May  7 16:31:42 2004].846551 HTTP: After download loop
[Fri May  7 16:31:42 2004].847062 msHTTPExecuteRequests() timing summary per
layer (connect_time + time_to_first_packet + download_time = total_time in
seconds)
[Fri May  7 16:31:42 2004].847617 Layer 0: 0.001 + 0.231 + 0.002 = 0.234s
[Fri May  7 16:31:42 2004].848405 msDrawRasterLayerLow(country): entering.
  File "./src/test.py", line 131, in ?
    image = mo.draw();
  File "/usr/lib/python2.2/site-packages/mapscript.py", line 1783, in draw
    def draw(*args): return apply(_mapscript.mapObj_draw,args)
_mapscript.MapServerError: msLookupHashTable: Hash table error. Invalid hash
table or key
Could anyone please give me a hint ?
Here my configuration files :
server.map map file of WMS
    NAME test_WMS_SERVER
    STATUS ON
    SIZE 600 600
    SHAPEPATH "/usr/local/apache2/wmsdata"
	IMAGECOLOR 60 175 220
	IMAGETYPE PNG
    WEB
        METADATA
           "wms_title"                   "WMS Demo Server"
            "wms_onlineresource"
"http://localhost:80/wms/mapserv?map=server.map&"
            "wms_srs"                    "EPSG:4326"
            "wms_format"                "image/png"
        END
    END
    LAYER
    		NAME country
    		STATUS ON
    		DATA country
    		TYPE POLYGON
    		CLASS
      			STYLE
        			COLOR 150 120 80
                    		OUTLINECOLOR 25 25 25
      			END
            END
    END
END
client.map map file of client app
# Start of map file
MAP
	NAME Mediteranean
	STATUS ON
	SIZE 600 600
	EXTENT 2.5256 21.5595 34.1734 53.2078
	SHAPEPATH "/root/projects/data"
    WEB
        IMAGEPATH '/root/projects/data/tmp/'
        IMAGEURL '/tmp'
        LOG "cascade_wms.log"
    END
	IMAGETYPE PNG
        INTERLACE OFF
    PROJECTION
        "init=epsg:4326"
    END
   # This the country layer coming from a WMS server
	LAYER
    		NAME country
    		STATUS ON
            OFFSITE 0 0 0
    		TYPE RASTER
            DEBUG ON
            CONNECTIONTYPE WMS
            CONNECTION "http://localhost:80/cgi-bin/mapserv?map=server.map&"
            METADATA
              "wms_title" "wms_COUNTRY"
              "wms_name"    "country"
              "wms_server_version" "1.1.1"
              "wms_srs" "epsg:4326"
              "wms_latlonboundingbox"   "-180 -90 180 90"
            END
            PROJECTION
                "init=epsg:4326"
            END
	END
END # end of map file definition
More information about the MapServer-users
