[Mapserver-users] WMS server - client communication error
Daniel Morissette
dmorissette at dmsolutions.ca
Fri May 7 12:53:01 EDT 2004
Sean Gillies wrote:
> The Python mapscript module is set up so that the MapServer error stack is
> checked after method calls (such as mapObj.draw), MapServer errors are
> converted to Python exceptions and are raised.
> Somewhere in msDrawMap, maybe in the WMS HTTP request code,
> msLookupHashTable
> is being used to access layer or map metadata and is not finding something
> it expects. Maybe your mapfile lacks a WMS metadata parameter?
> In the CGI MapServer, such an error will be reported but will
> not necessarily stop execution of the program. With the Python MapScript,
> unhandled exceptions will stop execution.
Ah... makes sense now. If you add a dummy METADATA block to your layer
definition then the error should go away. (I've been able to reproduce
here in the debugger.)
I have created bug 650 to discuss the solution to this problem:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=650
I'll make sure the fix makes it in v4.2
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
