[Mapserver-users] another error
Ethan Alpert
ealpert at digitalglobe.com
Mon May 10 17:54:52 EDT 2004
Do a "locate libproj"
Add it's directory to LD_LIBRARY_PATH
You'll need to add that also to your httpd.conf
SetEnv LD_LIBRARY_PATH /path/toproj/lib
-e
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of Zamil
Murji
Sent: Monday, May 10, 2004 3:28 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] another error
I configure my mapserver --with-proj=/usr/local and it compiled just
fine. When I copied the file over to my cgi-bin and run it, I get an
error.
[root at mayhem cgi-bin]# ./mapserv -v
./mapserv: error while loading shared libraries: libproj.so.0: cannot
open shared object file: No such file or directory
What am I missing? Do I need to add something to my LD_LIBRARY_PATH? I
am running RH 9.
Thanks
Zamil
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
