[Mapserver-users] JOIN fails and Xbase weeps
gacp
gacp at d-konstruktors.org
Sat May 8 08:05:41 EDT 2004
Hi all!
I've just started using MapServer. I've done quite a bit of reading so
far, (honestly, the docs are not much help) and have manage to build a
simple application (CGI MapServer), even to the point of creating layers
from a PostGIS connection.
But this has me totally baffled.
I am trying to make a JOIN of an ESRI DBF file from a shapefile (WWF
ecoregions). This join fails, but no error is logged in MapServer's
error file for this template.
LAYER
NAME "base"
TYPE QUERY
STATUS DEFAULT
DATA "gisdata-ro/Terra/vector/wwfecoregions/ecoregions"
TRANSPARENCY 66
# LABELITEM "Eco_name"
CLASS # main distro area
OUTLINECOLOR 81 127 81
COLOR 81 127 81
TEMPLATE "ecoregions.html"
END
METADATA
WMS_TITLE "main land stuff"
WMS_ABSTRACT "nil"
WMS_SRS "nil"
END
JOIN
NAME biome_test
TABLE "/var/www/html/mapserver/Terra/biome_names.dbf"
FROM "BIOME"
TO "CODES"
TYPE SINGLE
END
END
The result of the query has this ghostly message:
xbasewohoo
That's it. Nothing else.
Is this supposed to be an error message? "xbasewohoo"? TIA.
