[Mapserver-users] MapServer 4.2 beta 2
P Wilkerson
1wilkerson at charter.net
Sat May 8 22:10:37 EDT 2004
Daniel,
Thank you very much for the information.
You are exactly right!
Peter
----- Original Message -----
From: "Daniel Morissette" <dmorissette at dmsolutions.ca>
To: "P Wilkerson" <1wilkerson at charter.net>
Cc: "mapserver-users" <mapserver-users at lists.gis.umn.edu>
Sent: Saturday, May 08, 2004 3:42 PM
Subject: Re: [Mapserver-users] MapServer 4.2 beta 2
> P Wilkerson wrote:
> > A) Under the 4.2 beta, the ROSA applet returns the following:
> > Warning: Wrong parameter count for open() in
> > E:\ms4w\Apache\htdocs\gmap75.pdi on line 811
> > Fatal error: [MapServer Error]: msLayerGetShape(): Shapefile layer has
not
> > been opened. in E:\ms4w\Apache\htdocs\gmap75.pdi on line 842
> That's probably because the gmap_ms4w.zip you used is for version 3.6 of
> php_mapscript. In version 4.0 and 4.2 of php_mapscript, the call to
> $layer->open() and a few other calls have changed, and we had to update
> GMap accordingly.
> You could download and install GMap for MapServer 4.x from:
> http://maptools.org/dl/gmap-ms40.zip
> Note that this file is not a MS4W package, so you should extract it
> directly under the \ms4w\apps directory of your MS4W tree since the zip
> file doesn't include the \ms4w\apps\ path components.
> Daniel
> Daniel Morissette dmorissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
