[Mapserver-users] Install Problem on i668 Linux Using .tar.gz
Ben Minton
benminton at austarnet.com.au
Tue May 11 02:57:17 EDT 2004
Hi All
Installed Apache 1.3.29 on i686 Fedora Core 1. Works 100%. Standard installation.
Installing MapServer as per instructions @ URL http://mapserver.gis.umn.edu/doc40/unix-install-howto.html#compiling
Compiled fine. As per info
A simple test is to try and run it:
[user at host mapserver]$ ./mapserv
This script can only be used to decode form results and
should be initiated as a CGI process via a httpd server.
So it appears to have performed that action OK.
Next part, Installation, MapServer Binary is where I am getting stymied.
"The main goal is to get the "mapserv" binary installed in a publicly accessible directory that is configured to run CGI programs and scripts."
OK, but what is the MapServer Binary and where do I find it to move it?
"Under a default configuration, the CGI directory is "/usr/local/apache/cgi-bin" (RedHat users will use "/home/httpd/cgi-bin"). "
As I am using Fedora (based on rxx hxx) I checked /home/httpd --> no cgi-bin there.
While my apache install is actually in /usr/local/apache --> cgi-bin is there.
I have full /root on this sys so can edit apache files as required but don't understand this part.
Looked through Mail Archive, no solution.
Regards, Ben.
