[Mapserver-users] Re: help installing mapserver with ming
blaise
bpicinbono at worldonline.fr
Tue May 11 12:15:10 EDT 2004
Dear list,
Installing MapServer with Ming support partially solved.
(what a headache !)
After many days and even weeks working on that, I managed to compile
MapServer with the Ming support.
Here are my tricks, I put them on the list, hopping it can help some of
you. But I am not fully satisfied with that. I had to modify several
files that, I think, were not supposed to be modified. I don't think my
method is very academic, so don't take it as the Truth, but as possible
ways to help you with the Ming install.
Moreover, although the MapServer compilation runs to its end, it outputs
several warnings that make me think that everything is not ok.
Anyway, I a now able to run the FlashMapServer demo and I am going to
customize it to my needs. But, in this demo, I still have two main
problems :
-- big aliasing artefacts on the map (during the compilation, it
complains a lot with the php_mapscript_util.c and php_mapscript.c files
telling :
warning: dereferencing type-punned pointer will break strict-aliasing rules)
-- I haven't yet been able to output raster on the Flash demo.
If somebody know how to solve these problems, that will be greatly
welcomed ! ! !
So here are my tricks :
I am working on a linux box driven by Fedora Core 1a, Apache 2. I have
installed the Mapserver-4.0.2, Php-4.3.6, Ming-0.3a, GD-2.0.22 and other
libs from source.
The file tree of the installation stuff I used is :
/root/ms_install/mapserver-4.0.2 : mapserver
/root/ms_install/lib/php-4.3.6 : php
/root/ms_install/lib/ming : ming
/root/ms_install/lib/gd-2.0.22 : gd
/root/ms_install/lib/xxx : all other needed libraries.
I am NOT using GIF, don't have any gif support.
Files that I changed before installing Ming :
# cd /root/ms_install/lib
# tar -xzvf ming-0.3a.tar.gz
# cd ming
ming/config.h
edit /root/ms_install/lib/ming/config.h
replace line 2 :
#define USE_GIF 1
by :
#define USE_GIF 0
save the updated file
ming/config.make
edit /root/ms_install/lib/ming/config.make
replace line 2 :
EXTRA_OBJS = gifdbl.o pngdbl.o
by :
EXTRA_OBJS = pngdbl.o
and replace line 5 :
EXTRA_LIBS = -lz -lungif -lpng12
by :
EXTRA_LIBS = -lz -lpng12
ming/src/ming.h
edit /root/ms_install/lib/ming/src/ming.h in a text editor
remove these lines :
lines 156-159 :
#ifdef USE_GIF
SWFDBLBitmapData newSWFDBLBitmap_fromGifFile(char *name);
SWFDBLBitmapData newSWFDBLBitmap_fromGifInput(SWFInput input);
#endif
...save the updated file
ming/src/blocks/bitmap.c
edit /root/ms_install/lib/ming/src/blocks/bitmap.c in a text editor
lines 64-69 :
if(c1 == G && c2 == I)
#if 1
return (SWFBitmap) newSWFDBLBitmap_fromGifInput(input);
#else
SWF_error("GIF images must be translated into DBL files for now");
#endif
# cd /root/ms_install/lib/ming
# make
# make static
# make install
# cd php_ext
# make
# ldconfig
... make a 987.2 ko php_ming.so file in ming/php_ext... good
(this file has to go in the extensions directory of Php).
Files that I changed before installing MapServer :
# tar -xzvf mapserver-4.0.2.tar.gz
# cd mapserver
mapserver-4.0.2/mapswf.c
(very sensitive file ! ! ! )
line 827, replace :
char *driver = strdup("GD/GIF");
by
char *driver = strdup("GD/PNG");
delete lines 875 -877 :
#ifdef USE_GD_GIF
#else
delete one "#endif" line (line 890) : NO DONT DELETE THAT ONE, OR MAKE
WILL FAIL ! ! ! ( WHY ? THIS IS VERY STRANGE ! )
line 2422 replace :
const char *driver = "GD/GIF";
by ;
const char *driver = "GD/PNG";
delete line 2443 :
#endif
replace line 2805 :
by :
delete lines 2808 to 2810 :
#ifdef USE_GD_GIF
#else
delete line 2825 :
#endif
replace line 2728 :
SWFMovie_save(image->img.swf->sMainMovie, filename);
by :
SWFMovie_save(image->img.swf->sMainMovie, filename,0);
mapserver-4.0.2/map.h
edit mapservver/map.h
replace line 42 :
#include "ming.h"
by
#include "/root/ms_install/lib/ming/src/ming.h"
/usr/include/ming.h
edit file /usr/include/ming.h
replace line 41 :
#include "../config.h"
by :
#include "/root/ms_install/lib/ming/config.h"
save updated file
# cd /root/ms_install/mapserver-4.0.2
# ./configure --with-tiff --without-eppl --with-threads --with-proj
--with-php=../lib/php-4.3.6 --with-gd=/usr/local
--with-freetype=/usr/bin --with-ming
# make
As I said before, during the "make" of MapServer, I get a lot of
warnings, mainly of two kinds :
--1-- mapswf.c: warning: passing arg 2 of 'SWFButton_addShape' from
incompatible pointer type
--2-- php_mapscript_util.c and php_mapscript.c: dereferencing
As I am just discovering FlashMapServer, I haven't tested all the
available functions and can't tell that everything is working. I just
can run the FlashMapServer demo, but without raster and with big
aliasing artefacts.
Well, well, I hope this will help some of you, but I am also waiting for
a more academic way of installing MapServer with Ming
Bye
Blaise
