[Mapserver-users] SLD - wms_sld_url
Yewondwossen Assefa
assefa at dmsolutions.ca
Tue May 11 15:05:14 EDT 2004
Joost,
I just tried an example with wms_sld_url set with mapserver beta2 (as
well as the cvs version) and It works for me.
I do not see anything wrong in your example so not sure what is wrong
(if xml and url are valid).
Later,
Van Ulden, Joost wrote:
> Hello all,
> I am looking into SLD with MapServer. It works fine if I add the path to an
> SLD doc to the url, but when I specify the path in the wms_sld_url metadata
> element the style does not get applied. It works if I put the sld doc in
> the wms_sld_body. Maybe I am way off but here is my layer snippet:
> LAYER
> NAME "Styled Rivers"
> TYPE RASTER
> STATUS ON
> CONNECTION "http://127.0.0.1/scripts/mapserv.exe?map=wms.map"
> CONNECTIONTYPE WMS
> METADATA
> "wms_srs" "EPSG:4326"
> "wms_name" "Rivers"
> "wms_server_version" "1.1.0"
> "wms_format" "image/gif"
> "wms_sld_url"
> "http://127.0.0.1/mapserver/styles/sld_line_simple.xml"
> END
> END
> Any suggestions would be helpful.
> Cheers,
> Joost
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
