[Mapserver-users] Filtering shapes?
Ethan Alpert
ealpert at digitalglobe.com
Tue May 11 18:48:50 EDT 2004
This is a multi-part message in MIME format.
------_=_NextPart_001_01C437AA.205AD47E
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
Is there a way to filter snapes based on attributes?
=20
I have a shape file with each shape having a date and I want to display
only shapes within a certain date range. I used the FILTER layer
parameter when I was using postgis (which I can't do anymore because I
can't do a distinct select). Now I'm using a shape file.
=20
Thanks,
=20
-e
Content-Type: text/html;
charset="us-ascii"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD><TITLE>Message</TITLE>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Dus-ascii">
<META content=3D"MSHTML 6.00.2800.1400" name=3DGENERATOR></HEAD>
<BODY>
<DIV><SPAN class=3D267594522-11052004><FONT face=3DArial size=3D2>Is =
there a way to=20
filter snapes based on attributes?</FONT></SPAN></DIV>
<DIV><SPAN class=3D267594522-11052004><FONT face=3DArial=20
size=3D2></FONT></SPAN> </DIV>
<DIV><SPAN class=3D267594522-11052004><FONT face=3DArial size=3D2>I have =
a shape file=20
with each shape having a date and I want to display only shapes within a =
certain=20
date range. I used the FILTER layer parameter when I was using postgis =
(which I=20
can't do anymore because I can't do a distinct select). Now I'm using a =
shape=20
file.</FONT></SPAN></DIV>
size=3D2>Thanks,</FONT></SPAN></DIV>
size=3D2>-e</FONT></SPAN></DIV></BODY></HTML>
=00
------_=_NextPart_001_01C437AA.205AD47E--
