[Mapserver-users] geos + postgis + querybypoint
Vladimir Guzmán
bigfoot at main-task.com
Tue May 11 18:57:19 EDT 2004
Hello, list.
I have an application in php mapscript, using postgis, in a server
running RedHat 8.
The application works fine in this server.
I mounted exactly the same application in another server running SuSE 8.2.
The only difference is that I configured postgis with GEOS support in
the suse server.
Now I have problems making a querybypoint in some layers.
There is no problem drawing the layers.
I made a dump with pg_dump, and after restoring the dump in the suse
server, I made a VACUUM ANALYZE.
My question is: compiling postgis with GEOS alters the way mapserver
makes the queries?
Thanks a lot,
Vladimir Ilich Guzmán R.
http://maintask.com
