[Mapserver-users] Re: Clarifications about mapscript 4.2
Sean Gillies
sgillies at frii.com
Wed May 12 17:17:26 EDT 2004
Hey Eric,
I'm unable to reproduce your problems with my Python interpreter. Here
is a session below. I'm using the mapfile from the mapserver tests.
Python 2.3.3 (#1, Jan 4 2004, 11:27:28)
[GCC 3.2.2 20030222 (Red Hat Linux 3.2.2-5)] on linux2
Type "help", "copyright", "credits" or "license" for more
information.
>>> import mapscript
>>> test_map =
mapscript.mapObj('/home/sean/projects/ms_42/mapserver/tests/test.map')
>>> class00 = test_map.getLayer(0).getClass(0)
>>> s0 = class00.getStyle(0)
>>> s0
<C styleObj instance at _b0761808_p_styleObj>
>>> s0.color.toHex()
'#ff9966'
>>> s0.color.setRGB(0,0,0)
0
>>> s0.color.toHex()
'#000000'
>>> s0.color.setRGB(51,51,51)
0
>>> s0.color.toHex()
'#333333'
>>> s0.color.setRGB(102,102,102)
0
>>> s0.color.toHex()
'#666666'
I can't reproduce the sticking. Next a test with defined colors.
>>> blue = mapscript.colorObj(0,0,255)
>>> blue.toHex()
'#0000ff'
>>> s0.color = blue
>>> s0.color.toHex()
'#0000ff'
>>> red = mapscript.colorObj(255,0,0)
>>> s0.color = red
>>> s0.color.toHex()
'#ff0000'
>>> s0.color = blue
>>> s0.color.toHex()
'#0000ff'
So it appears that this is working OK as well.
Now, looking at your script, there is a line
$point->draw($map, $layerObj, $img, undef, "$point_id");
The fourth arg of pointObj::draw is supposed to be the classindex of the
appropriate class of your layer. I'm not at all sure what we'd expect
when we give it a NULL instead of an integer in the
range [0 .. $layerObj->{numclasses}). In your script it looks like
you should be passing a value of 0 instead of undef.
BTW, this reminds me how awful are the API for the various draw()
methods.
The above method should really be something like
pointObj::draw( imageObj img, classObj class, string text )
Since the layer and classindex arguments only serve to point to a class
anyway. It's awkward to be passing a mix of references and integer
indexes
to the class.
cheers,
Sean
On May 12, 2004, at 2:27 PM, Eric Bridger wrote:
> Hi Sean,
> I've been having trouble with styles and colors in Mapscript4.2b2. I've
> attached a small perl script and map file which demonstrates the
> problem.
> Loop thru some points, get the one class and style defined in the map
> file and change various attributes: size, symbol, color. I have no
> problem changing the class symbol or symbol size. But the color seems
> strangely "sticky". Whichever color is set first using
> $style->{color}->setRGB() remains in force. The color DOES change from
> the color defined in the mapfile but then will not change again.
> I've also found that (this is a separate problem)
> my $red_color = $mapscript::colorObj(255,0,0);
> $style->{color} = $red_color;
> does not work as expected. The color is always black in this case.
> Am I missing something? I will next attempt a completely dynamic
> approach, new class, new sytle, etc. and see if that works better.
> Thanks,
> Eric
> On Fri, 2004-05-07 at 13:21, Sean Gillies wrote:
>> Hi Eric,
>> Was just looking at your Wiki pages and have some clarifications
>> for you.
>> 1) STYLES: Most users will want to dynamically add new styles to a
>> class by
>> this syntax:
>> $class = $layer.getClass(0);
>> $new_style = mapscript::styleObj($class);
>> insertStyle() is for more specialized cases where you really want to
>> change
>> the ordering of styles or pass a fully-defined style around in your
>> app.
>> 2) SYMBOLS: I'd like to recommend that symbols be accessed through
>> methods of symbolSetObj class rather than through methods of mapObj.
>> For example:
>> $foo_index = $map->{symbolset}->index("foo");
>> is, IMO, the better way to go than
>> $foo_index = $map->getSymbolByName("foo");
>> The later is a poorly named function because it returns an integer,
>> not
>> a
>> symbol, compared to mapObj::getLayerByName which *does* return a
>> layer.
>> We're going to leave this in mapscript for backwards compatibility,
>> but
>> the future direction is to make mapObj, layerObj, classObj,
>> symbolSetObj,
>> etc more container-like with index() methods that return the index of
>> a "child" object given the child's name, and that getFoo() methods
>> uniformly return instances of Foo, not a mix of instances and indexes.
>> 3) You might want to point folks to the development documentation
>> which
>> is
>> committed in CVS under mapserver/mapscript/doc/mapscript.txt and to
>> the
>> HTML document that I have been generating and keeping online at
>> http://users.frii.com/sgillies/projects/mapscript/
>> cheers,
>> Sean
>> Sean Gillies
>> sgillies at frii dot com
> <test_color.cgi><test_color.map>
