[Mapserver-users] proj4 and mapserver
Agneta Schick
schick at sdac.hannover.bgr.de
Thu May 13 07:59:25 EDT 2004
Dear reader,
I'm trying to display a layer of symbols which are lat/long coordinates (from
shape files) on a map in winkel tripel projection (generated by GMT).
My problem is when I DO NOT specify "projection latlong" in the map file for
the layer with symbols, the symbols are displayed but, of course, in the
wrong place and when I specify "projection latlong" the symbols are not
displayed at all. I assume that my specifications for the winkel tripel
projection are not correct/complete.
Using "proj -l=wintri" I get
wintri : Winkel Tripel
Misc Sph
lat_1
Does this mean that "lat_1" is the only information I need supply for the
projection definition aside from "proj=wintri"?
I've defined the map extents as -140 -90 220 90 with units dd. Can I use
degrees when using proj4 although the output from proj is meters?
I'm using MapServer version 4.0.1, gdal-1.1.9, libpng-1.2.5, proj-4.4.7,
Shape-0.04, shapelib-1.2.10 on Solaris9.
Thank you,
Agneta Schick
MAP
NAME "ERMOS"
STATUS ON
EXTENT -140. -90. 220. 90.
UNITS DD
SIZE 947 612
SHAPEPATH "/space/b3sn13/webdb/htdocs/ermos/data"
IMAGECOLOR 255 0 0
IMAGETYPE png
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS
1 1
END
FILLED TRUE
END
PROJECTION
"proj=wintri"
"lat_1=0"
"lon_0=40e"
END
LAYER
NAME 'world'
DATA /space/b3sn13/webdb/htdocs/ermos/data/wintri.tif
TYPE RASTER
STATUS DEFAULT
END
LAYER
NAME 'quakes'
DATA 'usgs'
TYPE POINT
STATUS ON
PROJECTION
"proj=latlong"
"datum=WGS84"
END
CLASS
SYMBOL 'circle'
SIZE 5
OUTLINECOLOR 0 0 0
COLOR 255 0 0
END
END
END
