[Mapserver-users] Re: Clarifications about mapscript 4.2
Eric Bridger
eric at gomoos.org
Thu May 13 09:09:20 EDT 2004
On Wed, 2004-05-12 at 17:13, Sean Gillies wrote:
> Hey Eric,
> I'm unable to reproduce your problems with my Python interpreter. Here
> is a session below. Note that I'm using the next generation class
> names ... 'Map' is exactly the same as 'mapObj', 'Color' == 'colorObj',
> &c.
> Python 2.3.3 (#1, Jan 4 2004, 11:27:28)
> [GCC 3.2.2 20030222 (Red Hat Linux 3.2.2-5)] on linux2
> Type "help", "copyright", "credits" or "license" for more
> information.
> >>> import mapscript
> >>> test_map =
> mapscript.Map('/home/sean/projects/ms_42/mapserver/tests/test.map')
> >>> class00 = test_map.getLayer(0).getClass(0)
> >>> s0 = class00.getStyle(0)
> >>> s0
> <C styleObj instance at _b0761808_p_styleObj>
> >>> s0.color.toHex()
> '#ff9966'
> >>> s0.color.setRGB(0,0,0)
> 0
> >>> s0.color.toHex()
> '#000000'
> >>> s0.color.setRGB(51,51,51)
> 0
> >>> s0.color.toHex()
> '#333333'
> >>> s0.color.setRGB(102,102,102)
> 0
> >>> s0.color.toHex()
> '#666666'
> I can't reproduce the sticking. Next a test with defined colors.
> >>> blue = mapscript.Color(0,0,255)
> >>> blue.toHex()
> '#0000ff'
> >>> s0.color = blue
> >>> s0.color.toHex()
> '#0000ff'
> >>> red = mapscript.Color(255,0,0)
> >>> s0.color = red
> >>> s0.color.toHex()
> '#ff0000'
> >>> s0.color = blue
> >>> s0.color.toHex()
> '#0000ff'
> So it appears that this is working OK as well.
> Now, looking at your script, there is a line
> $point->draw($map, $layerObj, $img, undef, "$point_id");
Sean,
Perl mapscript4.2b2 works in the above cases as well. The problem seems
to lie deeper, in the point->draw() method, i.e. even when
style->toHex() reports #0000ff, point->draw() draws a black or whatever
color was first set. I will continue to investigate.
Eric
