[Mapserver-users] postgis and java mapscript
Tomas Brandalik
Tomas.Brandalik at Sun.COM
Fri May 14 03:14:13 EDT 2004
ok, that was wrong compilation without postgis support. Now it works
fine with these settings:
CCFLAGS=-DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_TIFF -DUSE_JPEG
-DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL
LDFLAGS=-L/usr/local/lib/swig1.3 -L../.. -L. -lmap -lgd -L/usr/local/lib
-lgd -ljpeg -lfreetype -lpng -lz -ltiff -ljpeg -lgdal
-L/usr/local/pgsql/lib -lpq -lm -lstdc++
-Tomas
Tomas Brandalik wrote:
> No, I use same map file and generate only simple png without any
> manipulation. But maybe problem is in compilation libmapscript.so
> with postgis enabled. I am not sure if I did it properly. will
> investigate further
> -Tomas
> Sean Gillies wrote:
>> On May 13, 2004, at 9:24 AM, Tomas Brandalik wrote:
>>> I am running mapserver4.0.2 compiled with postgis0.8.1 extension. It
>>> works fine through cgi but not from java/mapscript.
>>> java/mapscript library generates expected png file if datasources
>>> were shapefiles but no output or even error shows up when
>>> datasources were postgis.
>>> I can't find any log or whatever would help me find the problem.
>>> Have anybody seen this before?
>>> -Tomas
>> Tomas, mapscript uses the same code as mapserver, so this is unexpected.
>> Are you using the same map config file in each case? Are you using
>> mapscript to modify any of the postgis layer's attributes? Setting
>> filters or classitems?
>> Sean
>> Sean Gillies
>> sgillies at frii dot com
>> http://users.frii.com/sgillies
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
