[Mapserver-users] Accessing uppercase tables with a PostGIS connection
David Blasby
dblasby at refractions.net
Fri May 14 15:56:33 EDT 2004
Jeff McKenna wrote:
> yes i wrote that wrong..i meant a column name, sorry. The column name
> is ""CST00SRF" . I want to avoid having to reload all of the data (with
> the LAUNDER option). Is that my only option?
You can try using quotes around your column name in the DATA statement.
Otherwise, you can do this:
ALTER TABLE <table> RENAME COLUMN "CST00SRF" TO cst00srf;
dave
