[Mapserver-users] Mapserver Newbie Quests
Richard Greenwood rich at greenwoodmap.com
Sat May 15 11:10:04 PDT 2004
Tyler Mitchell wrote:
>>I have set up Mapserver Win Binaries (4.2 beta2) on a Windows 2000
>>Server Machine, because of the ECW Support of GDAL. The Server only
>>should Serve a bunch of ECW Color Images per OGC Service at a good
>>performance. So I created a tile index over the Fotos (~10000
>>Mosaics in endconfig) as shapefile. This works fine but there are
>>also a lot of problems, I can not solve with my mapserver skills.
>>Problem 1: Can I use a tile index, served by a PostGIS Database? Is
>>that faster (more perormance)?
> I think that your shape file tile index is probably going to be faster, in
> theory, than PostGIS.  The nature of MapServer is that PostGIS calls have
> to go through a couple more levels to get your answer, whereas shape files
> are bit more simple.
>>Problem 2: When I zoom out too much, mapserver needs exponentially
>>more time to process the input ecw´s to a output jpeg. How can I
>>tune that best? (Pyramids? How?)
> ECW's, by nature, have a type of pyramids already.
Even if GDAL is using ECW's built-in pyramids, the overhead of opening
~10000 files would be significant. I'd recommend pyramids. Maybe fewer
than you would use with tiffs. Patch your images together and down
sample them.
>>Problem 3: On the Server, there are running lots of instances of
>>mapserv.exe, which I can´t kill, because "Acces denied!" (I´m root
>>on that machine). COuld there be some misconfiguration?
Those are probably instances of mapserv.exe that died. Get the
"kill.exe" tool from the NT Resource Kit (or Google it).
>>Problem 4: I´m testing this configuration (mapserver + ecw Imagery +
>>tile index), to find a method to serve very large raster data for
>>our ArcIMS Services, ArcGIS Applications and AutoCAD Clients. Do you
>>think, there might be a better solution? For my part, mapserver
>>could do this good (if I could admin it perfectly), but maybe there
>>is a much better solution.
ER Mapper has an ECW Image Web Server. Don't know much about it, but it
sounds like what you are looking for.
Rich
Richard Greenwood
www.greenwoodmap.com
More information about the MapServer-users mailing list
