[Mapserver-users] Hyperlinks from map layers
Kenneth Slot
kenneth at kongsbak.dk
Mon May 17 04:45:33 EDT 2004
This is a multipart message in MIME format.
--=_alternative 00330A95C1256E97_=
Content-Type: text/plain; charset="US-ASCII"
I have a 2 layers called plan_poly the other called plan_line. As the
title says on layer type is Polygon and the other is Line.
Both layers contains the same columns Title, Desciptions and Doclink.
The doclink contains link to a given PDF document on a webserver.
http://www........../1-1.pdf
I want to makes these doclinks active as hyperlinks, so i can click on the
map with the "i" button and be redirected to the pdf-document.
Is that possible? If so how do i activate my layers?
I'm using MapLap and Mapserver newest version. On Microsoft Internet
Informations Server.
Thanks
Kenneth
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">I have a 2 layers called plan_poly the
other called plan_line. As the title says on layer type is Polygon and
the other is Line.</font>
<br><font size=2 face="sans-serif">Both layers contains the same columns
Title, Desciptions and Doclink.</font>
<br><font size=2 face="sans-serif">The doclink contains link to a given
PDF document on a webserver. http://www........../1-1.pdf</font>
<br><font size=2 face="sans-serif">I want to makes these doclinks active
as hyperlinks, so i can click on the map with the "i" button
and be redirected to the pdf-document. </font>
<br><font size=2 face="sans-serif">Is that possible? If so how do i activate
my layers?</font>
<br><font size=2 face="sans-serif">I'm using MapLap and Mapserver newest
version. On Microsoft Internet Informations Server. </font>
<br>
<br>
<br>
<br><font size=2 face="sans-serif">Thanks</font>
<br>
<br><font size=2 face="sans-serif">Kenneth</font>
--=_alternative 00330A95C1256E97_=--
