[Mapserver-users] Does GDAL/OGR default compilation include Oracle Non-sSpatial Table support?
Geng, Xiaoyuan
Gengx at AGR.GC.CA
Mon May 17 14:46:33 EDT 2004
This is a multi-part message in MIME format.
------_=_NextPart_001_01C43C3F.4690AF2B
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
Hi
=20
I need to use OGR connection to access non-spatial Oracle table using
SQL statement. I would like to know that if the GDAL/OGR default
compilation includes the Oracle table access already. If not, what is
the example to compile GDAL/OGR to include the Oracle(do not have to be
Oracle Spatial) support? When do you think that Mapserver can let us
connect to a SDE layer and another separate Oracle table for Attribute?
=20
Thank you very much!
=20
Xiaoyuan Geng
Content-Type: text/html;
charset="us-ascii"
<html>
<head>
<meta http-equiv=3DContent-Type content=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DGenerator content=3D"Microsoft Word 10 (filtered)">
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{margin:0in;
margin-bottom:.0001pt;
font-size:12.0pt;
font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
span.EmailStyle17
{font-family:Arial;
color:windowtext;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;}
div.Section1
{page:Section1;}
</style>
</head>
<body lang=3DEN-CA link=3Dblue vlink=3Dpurple>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'>Hi</span></font></p>
font-family:Arial'> </span></font></p>
font-family:Arial'>I need to use OGR connection to access non-spatial =
Oracle
table using SQL statement. I would like to know that if the GDAL/OGR =
default
compilation includes the Oracle table access already. If not, what is =
the
example to compile GDAL/OGR to include the Oracle(do not have to be =
Oracle
Spatial) support? When do you think that Mapserver can let us connect to =
a SDE
layer and another separate Oracle table for Attribute?</span></font></p>
<p class=3DMsoNormal><font size=3D3 face=3D"Times New Roman"><span =
style=3D'font-size:
12.0pt'> </span></font></p>
style=3D'font-size:
12.0pt'>Thank you very much!</span></font></p>
style=3D'font-size:
style=3D'font-size:
12.0pt'>Xiaoyuan Geng</span></font></p>
</div>
</body>
</html>
------_=_NextPart_001_01C43C3F.4690AF2B--
