[Mapserver-users] Compile Mapserver 4.0.1 - gdal-1.1.9
Daniel Morissette
dmorissette at dmsolutions.ca
Tue May 18 09:30:25 EDT 2004
Rolando Riley wrote:
> Hello Guys:
> I have been following your directions to compile mapserver with support
> to OGR. Each time I try to do it I get this error. What is wrong?
> ./configure --with-httpd=/usr/sbin/httpd --with-gdal=/usr/local/bin/gdal-con
> fig --with-proj=/usr/ --with-tiff=/usr --with-ogr=/home/rriley/gdal-1.1.9/og
> r/ --with-wfs --with-wfsclient
The problem may be related to your attempt to use of two different
versions of GDAL in your build:
--with-gdal=/usr/local/bin/gdal-config
--with-ogr=/home/rriley/gdal-1.1.9/ogr/
Since OGR is part of GDAL, you need to point both to the same location,
or specify the location in only one of the two options and the other one
will follow, e.g.
--with-gdal=/usr/local/bin/gdal-config --with-ogr
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
