[Mapserver-users] Large Raster files
Tyler Mitchell TMitchell at lignum.com
Tue May 18 08:19:02 PDT 2004
You still need to setup PROJECTION for your ortho layers so that Mapserver
knows what projection they are in.  Have you done that?
mapserver-users-admin at lists.gis.umn.edu wrote on 05/18/2004 03:53:41 AM:
> I have a question regarding the relationship between PROJECTION and
> EXTENT for the display of layers in the mapfile  (mapserve src 4.02 and
> the new 4.2beta) I have managed to get a custom region working using the
> mapderve cgi tutorial files as a start. I have successfully displayed
> and tiled natural color ortho tiffs in EPSG:32115 (NY East state plane),
> and I have succeeded with a UTM location that displays shape files in
> EPSG:26918 (UTM 18N NAD83 GRS80).
> I have downloaded 302 world-file-referenced tiffs with the 1:24000 scale
> topo info for NYS. These are in EPSG:26918 (UTM 18NnAD83 GRS80)  and the
> extents, coordinate system and mapping have been verified in my GIS
> program (grass 5.03).  These files will not display, neither as single
> maps nor as a tiled map, even though the shapefile for the TILEINDEX
> (with the exact same coord parameters) displays just fine (I even got a
> county line shapefile map in latlong coordinates to plot properly on the
> UTM basemap). No errors in the logs.  I used .tfw and .wld and internal
> GeoTiff (gdal_translated) files all with the same null result.
> I have searched and read the posts on related problems, and it seems I
> have considered al the possibilities listed. I tried a gdalwarp into
> state plane (tiff output) coordinates to see if I could "TRANSFORM" it
> onto the base EPSG:26918 map, but failed to get anything more than the
> blank map frame.
> Is there something about UTM and EPSG I am missing, at least as they
> concern mapserver?
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
