[Mapserver-users] MapServer 4.2 beta3
Paul Spencer
spencer at dmsolutions.ca
Tue May 18 12:59:14 EDT 2004
Opps, thanks for pointing these issues out Tom.
I've recompiled the mapserv executables against the correct version of
xerces and added postgis input support, updated the zip files, and
reposted them under the identical name (the corrected URL for the ms4w
package is below too).
http://maptools.org/dl/mapserver-4.2b3-win32-php4.3.4.zip
http://maptools.org/dl/ms4w/mapserver_ms4w-4.2b3-20040517.zip
Cheers,
Paul
PS pls bear with me, this is the first time I've had to fill Assefa's
shoes ... he has big feet! :)
Kralidis,Tom [Burlington] wrote:
>>-----Original Message-----
>>From: Daniel Morissette [mailto:dmorissette at dmsolutions.ca]
>>Sent: Tuesday, May 18, 2004 9:21 AM
>>To: mapserver-users
>>Subject: [Mapserver-users] MapServer 4.2 beta3
>>MapServer 4.2 beta3 has been posted to the download page of
>>the website.
>>The list of fixes in this new beta is at the end of this message.
>>For Windows users, a new build is available at
> Mapserv is looking for xerces-c_1_7_0.dll, which doesn't exist in above
> zipfile.
>>And for those using MS4W (http://maptools.org/ms4w/), an
>>update package
>>for MS4W is available at
>>http://maptools.org/dl/mapserver_ms4w-4.2b3-20040517.zip
> This URL gives me a 404.
>>Once again, we invite you to test this new beta and report
>>any critical
>>issue... and we hope (again!) that this could be the last beta before
>>the release.
>>Daniel
>> Daniel Morissette dmorissette at dmsolutions.ca
>> DM Solutions Group http://www.dmsolutions.ca/
>>Version 4.2-beta3 (2004-05-14)
>>- Fixed another write past end of buffer in INIMAGE WMS
>>errors (bug 644)
>>- Removed "xbasewohoo" debug output when using JOINs and fixed a few
>> error messages related to MySQL joins (bug 652)
>>- No more Python-stopping but otherwise benign errors raised from
>> msDrawWMSLayer() (bug 650).
>>- Finished prototyping all MapServer functions used by SWIG-Mapscript
>> and added 'void' to prototypes of no-arg functions, eliminating all
>> but two SWIG-Mapscript build warnings (bug 658).
>>- Fixed mapwcs.c so that gdal.h and cpl_error.h are not included if
>> USE_WCS_SVR is not enabled ... which is never is in 4.2.
>>- msBuildPath() no longer used with temporary filenames when
>>saving images
>> via GDAL.
>>- Bug 493: fix the raster cracking fix. The last fix
>>introduced a serious
>> heap corruption / errant pointer problem in some render cases.
>>- Resolved issue with pens and dynamically drawing points (bug 663).
>>- Removed unused metadata gml_uri in WFS code (Bug 527)
>>_______________________________________________
>>Mapserver-users mailing list
>>Mapserver-users at lists.gis.umn.edu
>>http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
|Paul Spencer pspencer at dmsolutions.ca |
|Applications & Software Development |
|DM Solutions Group Inc http://www.dmsolutions.ca/|
