[Mapserver-users] Python MapScript Tests Problems ("segmentation
fault")
Jan Schüngel
jschuengel at intevation.de
Wed May 19 10:21:42 EDT 2004
hi,
now i hab gdal support build in.
i creat the Mapserver this way:
./configure --with-proj --with-gdal.
make
so all works fine.
than mapscript
python setup.py build
python setup.py install
but wit gdal support the import of mapscript dont work
i get the new error :
Python 2.3.3 (#2, May 1 2004, 06:12:12)
[GCC 3.3.3 (Debian 20040401)] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import mapscript
File "<stdin>", line 1, in ?
File "mapscript.py", line 4, in ?
import _mapscript
ImportError: /usr/lib/python2.3/site-packages/_mapscript.so: undefined
symbol: CPLFreeConfig
without gdal support everything works find here, but i need gdal support.
Jan
Sean Gillies schrieb:
> Jan,
> The tests of appending new output formats will fail unless you
> are linking MapServer and mapscript to GDAL. This is because we
> are attempting to create a new GeoTIFF output format. Since the
> GD formats are already built into MapServer, we can't test adding
> a GD format.
> If you *are* linking to GDAL and the tests continue to fail, I
> would like to hear more.
> I see you are using GD 1.8! You should upgrade to the latest
> stable (at least 2.0.15+) immediately to take advantage of newer
> features and GD+Freetype bug fixes.
> cheers,
> Sean
> On May 19, 2004, at 6:35 AM, Jan Schüngel wrote:
>> Hi Michael
>> i use MapServer 4.2beta2 with python 2.3, gdal 1.2.0, gd 1.8.3-2
>> at the moment i upgrade debian sarge to get the newest lib files.
>> i hope that it will solve my problem.
>> If i run the test without the two tests, i get only 1 fail, that
>> shoud be
>> and 1 error in testShapeCopy (need 2 Arguments, only 1 given)
>> Michael Schulz schrieb:
>>> Hi Jan,
>>> which version of mapserver are you trying? The latest tests i ran
>>> with python mapscript are of version 4.2beta2 and had no
>>> segmentation faults, only:
>>> FAILED (failures=2, errors=1), ERROR: testShapeCopy
>>> This is with gd-2.0.21, gdal 1.2.0, python 2.1.3.
>>> Cheers, Michael
>>> Jan Schüngel schrieb:
>>>> Hi,
>>>> i have severall problems by testing the Python MapScript.
>>>> Installing and working is fine, but during the Tests i get a
>>>> "segmentation fault"
>>>> in Funktions:
>>>> testAppendNewOutputFormat
>>>> OutputFormatConstructor
>>>> on the Line:
>>>> new_format = mapscript.outputFormatObj('GDAL/GTiff', 'gtiff')
>>>> i think that the problem is with gdal, but i don't find any solution.
