[Mapserver-users] Deriving TIGER extents
Frank Warmerdam
warmerdam at pobox.com
Thu May 20 00:38:57 EDT 2004
> Any suggestions?
> -- Marvin Humphrey
> EXTENT -91 41 -81 48
> #Longitude: 82° 26' W to 90° 31' W
> #Latitude: 41° 41' N to 47° 30' N
> LAYER
> NAME "tigertest"
> TYPE line
> CONNECTIONTYPE OGR
> CONNECTION "../TGR26049"
> DATA "CompleteChain"
> STATUS ON
> END
Marvin,
First, don't you need a CLASS statement in your line layer to define
how to draw the lines? Something like:
LAYER
NAME "tigertest"
TYPE line
CONNECTIONTYPE OGR
STATUS ON
CLASS
COLOR 255 0 0
END
END
Perhaps there is some reasonable default I don't know about.
Second, I don't have any problem getting extents from ogrinfo when
I specify a spatial layer (such as CompleteChain). For example:
warmerda at gdal2200[108]% ogrinfo -ro -summary . CompleteChain
INFO: Open of `.'
using driver `TIGER' successful.
Layer name: CompleteChain
Geometry: Line String
Feature Count: 34768
Extent: (-121.560168, 34.543146) - (-80.859591, 45.118070)
Layer SRS WKT:
GEOGCS["NAD83",
DATUM["North_American_Datum_1983",
SPHEROID["GRS 1980",6378137,298.257222101]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]]
MODULE: String (8.0)
TLID: Integer (10.0)
SIDE1: Integer (1.0)
In the above case there were a few random counties from around the country
in the directory so the extents are large, but if you only provide one county
is should be the appropriate country extents.
Good luck,
and watch the world go round - Rush | Geospatial Programmer for Rent
