[Mapserver-users] Fill Polygons
Paul Spencer
spencer at dmsolutions.ca
Thu May 20 08:25:32 EDT 2004
Note that this makes the entire layer transparent, including polygon
outlines. If you want solid outlines and tranparent fills, you will
need two separate layers.
Paul
Bart van den Eijnden wrote:
> Hi,
> you can use TRANSPARENCY for this, see:
> http://mapserver.gis.umn.edu/doc40/mapfile-reference.html
> TRANSPARENCY [integer]
> Sets the transparency level of all classed pixels for a given layer. The
> value is a percentage (0-100) where 100 is opaque and 0 is fully
> transparent.
> Best regards,
> Bart
> On Thu, 20 May 2004 13:19:47 +0200, Scott Ainslie <dmi at webmail.co.za>
> wrote:
>> Can I make the fill color of polygons transparent, ie: able to see layers
>> underneath?
>> Thanks
>> Scott
>> Mapserver-users mailing list
>> Mapserver-users at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
|Paul Spencer pspencer at dmsolutions.ca |
|Applications & Software Development |
|DM Solutions Group Inc http://www.dmsolutions.ca/|
